text problems and Not working the output testing.
Discussion in 'SimTools DIY Version' started by hunijjang, Jun 18, 2015.
  1. hunijjang
    hunijjang She is my wife :) Gold Contributor
    Operator
    Seoul, Korea
    1,164Coins
    Hello All. :)
    I just started testing with Simtool.
    It is still not moved... I just adjust and test then again and test.
    When I take by in the Jrk Configuration Utility, It is moved. anyway...
    first, there is texts some had problems. :(
    second, I use to Pololu JRK 12V12, so there is being to Command Port(COMx) and TTL Port(COMx).
    but I don't work any ports for output testing section. It is normal?
    P.S : I added for my SimTools Game Engine Settings.
    Simtool_text_1.png Simtool_text_2.png Simtool_text_3.png Simtools_setting_1.png Simtools_setting_2.png Simtools_setting_3.png Simtools_setting_4.png
    152,603Coins
    +11,087 / 56 / -2
  3. hunijjang
    Operator
    Seoul, Korea
    1,164Coins
    Hello, @noorbeast :)
    Thanks your answer.
    but I already checked it display options for 100% text size and not working. I use to Windows 7 Home Premium K 64bit.
    ah My Game Engine Interface output is not all the Axis1.(Interface 1 : <221><Axis1>, 2 : <221><Axis2>, 3 : <221><Axis3>) so Please disregard this in the setting pictures. :oops:
    and What I mean, Port is the in the device manager and there is some difference of the named. ex) Command Port and TTL Port, so I will setup to the only Command port in the SimTools Game Engine Interface settings?
    yes, I downloaded it by bsft's Jrk Guide
    152,603Coins
    +11,087 / 56 / -2
    Try setting English as the default language, SimTools does not do so well with other language settings.
    Yes command port.
  5. hunijjang
    Operator
    Seoul, Korea
    1,164Coins
    Hello @noorbeast
    Thanks again.
    Ok, I will try setting, Korean to English as the default windows language then will test again what is happen it is...
  6. hunijjang
    Operator
    Seoul, Korea
    1,164Coins
    Hello All.
    I don't think about this fonts problem for langauge. because other screen is normal.
    e.x) output testing fonts no issue of that is why?
    also I did change from Korea to USA .
    English, in the windows locate settings.
    but all the same of problem for fonts dismatch.
    @value1 and @yobuddy Hello :) do you known the what is the problems of me?
    Jrk 12v12 is not working to output testing funtions? or not? :(
    Thanks and then... :sos
  7. insanegr
    insanegr !N$@n€
    Athens
    16,725Coins
    @hunijjang did you go in control panel - region and language and change Format , Location tabs and on administrative tab the Language for non-Unicode programs , into English?
    give it a try if you haven't done it
  8. hunijjang
    Operator
    Seoul, Korea
    1,164Coins
    Hello @insanegr :)
    Thanks a lot mate. :D I do this test today and function is activated as your guide when I change the date and time format, and the locale is set to US English. Thanks again and I hope this guidence to update in the SIMTOOLS manuals soon. However, the font does not fix the problem. :(
    152,603Coins
    +11,087 / 56 / -2
    There is something really odd with your settings!
    Another thing you could try is right-click on each of the SimTools shortcuts and then click Properties. On the Compatibility tab select Disable Display Scaling On High DPI Settings, and then click OK.
    Let us know if that makes a difference.
  10. yobuddy
    51,224Coins
    I believe all gui related problems are fixed in v1.4 and the up and coming v2.0.
  11. hunijjang
    Operator
    Seoul, Korea
    1,164Coins
    Hello @noorbeast
    Thanks for advised so, I tired but that is not working. :( no dffierence.
    But Thanks to you. :D
  12. hunijjang
    Operator
    Seoul, Korea
    1,164Coins
    Hello @yobuddy
    I am depressed for this problems. :(
    however, thanks great news, I hope that be release very soon V1.4. :D
    cheer up~ ;)
  13. eaorobbie
    20,488Coins
    OK with the testing issue , have you set the default axis setting as I could not see a picture for this.
    The Output tests section only works with the default axis assignment and not a game assignment.
    When setting SimTools up for the first time this is clearly stated in the main docs, but I don't have a step to step method as its designed for diy simulator builders not newbies. Sorry a better manual is on the horizon and Im open to adding more to it if needed.
  14. hunijjang
    Operator
    Seoul, Korea
    1,164Coins
    Hello @eaorobbie :)
    Thanks and that is ok.
    when I joined to XSimulator then I am having the best time here.
    also that's what keeps me going ;)
    Thanks again. :D
  15. yobuddy
    51,224Coins
    @hunijjang
    It looks like you have spaces in your interface settings...
    Try this "<221><63>" and not this "<221> <63>" - remove the spaces.
    let me know how it goes...
  16. hunijjang
    Operator
    Seoul, Korea
    1,164Coins
    Hello @yobuddy :)
    but It is not added spaces. :rolleyes:
    by the way, that is working well and sorry for be tardy a answering a reply to you.
    @value1 Hello ;)
    I have a question to you.
    How can I change to the Extra 1 - PITCH and Extra 2 : ROLL?
    Thanks.
  17. value1
    15,078Coins
    Hi @hunijjang
    You cannot change pitch and roll to extra1 and extra2. These values are hardcoded.
    What you can change is the axis and the interface settings.
  18. hunijjang
    Operator
    Seoul, Korea
    1,164Coins
    Hello @value1
    Thanks but this http://www.xsimulator.net/community/threads/getting-the-most-out-of-p3d-and-your-sim.6889/
    There are guidences, Pitch and Roll is extra axis in use or something misunderstand me? some wrong? :eek:
    It is for the P3D but I want to be test it for X-Plane.
    because, I tested with the X-Plane at last time, something that was sensitive moved.
    152,603Coins
    +11,087 / 56 / -2
    The plugin for Prepar3D had the additional functionality added which allows for settings as per that guide, X-Plane has not.
  20. hunijjang
    Operator
    Seoul, Korea
    1,164Coins
    Hello @noorbeast
    I tested for 1~3 axis and includes roll, pitch, heave, sway, surge with X-Plane.
    I did use to Tuning Center and roll and pitch axis max values is looks well but heave, sway, surge values very low. e.x) heave is below about 5% and sway, surge is about 1-2% for max values.
    I think that of values something wrong maybe...
    @value1 It is normal? :(
