Actuators move randomly in LFS
Discussion in 'SimTools DIY Version' started by zhangxiaobao, Jun 15, 2015.
  1. noorbeast
    153,914Coins
    +11,154 / 57 / -2
    What simulator hardware did you test LFS on @fzxj520?
  2. fzxj520
    fzxj520 Active Member
    1,341Coins
    Output to SketchUp 8
    153,914Coins
    +11,154 / 57 / -2
    Can you possibly post the sketchup file for testing @fzxj520?
  4. fzxj520
    1,341Coins
    Sorry! Did not understand, could not guess the meaning of。
    153,914Coins
    +11,154 / 57 / -2
    Can you please upload the Sketchup file you tested LFS with.
  6. zhangxiaobao
    zhangxiaobao New Member
    300Coins
    SCN5, 6DOF
  7. fzxj520
    1,341Coins
    Move the slider to see the SimTools \ output testing \ Virtual Interface,
    But SimTools not connect SketchUp 8 (already installed "rubyinstaller-1.8.7-p302, exe" \\\\ socket.so \\\\ Wackelstuhl.rb)
    I guess might be "Ruby187" cause can not be connected.
    Because I did not find "Ruby186" installation package.
    Tutorial:How to Connect SimTools to SketchUp
    Just beginning to learn Google SketchUp 8
  8. fzxj520
    1,341Coins
    chengdu 。How about you?
  9. zhangxiaobao
    300Coins
    SCN5, 6DOF
    Currently studying in Jilin University. If you would, I could help you with translation.
    现在吉林大学。你愿意的话,我可以帮你翻译。
    • Friendly Friendly x 2
  10. fzxj520
    1,341Coins
    Hello noorbeast, thank you for your reply!
    Sorry it back to you, before the file is too simple, so I re-create the file and upload.
    • Windows8.1 x64
    • I've installed the correct version (Google sketchup WZH_8.0.16846.0.exe; rubyinstaller-1.8.6-p398.exe; SketchyPhysics3.2-Dec2.exe).
    • And copy files (socket.so, Wackelstuhl.rb) to (D: \ soft \ Google \ Google SketchUp 8 \ Plugins)
    but SimTools not properly connected with SketchUp SimTools. Whenever SimTools GameEngine \ Output Testing, SketchUp after the play button is pressed, the model disappeared. (Using file Wackelstuhl)
  11. fzxj520
    1,341Coins
    NET Error Messages
    Code:
    System.OverflowException: Arithmetic operation resulted in an overflow.
       at SimTools_GameEngine.frm_GameEngine.tmr_VirtualAxes_Tick(Object sender, EventArgs e)
       at System.Windows.Forms.Timer.OnTick(EventArgs e)
       at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
    mscorlib
        Assembly Version: 4.0.0.0
        Win32 Version: 4.0.30319.34014 built by: FX45W81RTMGDR
    SimTools_GameEngine
        Assembly Version: 0.1.3.0
        Win32 Version: 0.1.3.0
        CodeBase: file:///C:/Program%20Files%20(x86)/SimTools/SimTools_GameEngine.exe
    Microsoft.VisualBasic
        Assembly Version: 10.0.0.0
        Win32 Version: 12.0.20806.33440 built by: FX45W81RTMREL
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
    System
        Win32 Version: 4.0.30319.34003 built by: FX45W81RTMGDR
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
    System.Core
        Win32 Version: 4.0.30319.33440 built by: FX45W81RTMREL
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System.Drawing
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    System.Runtime.Remoting
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
    System.Configuration
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    System.Xml
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
    Microsoft.GeneratedCode
        Assembly Version: 1.0.0.0
    Accessibility
        CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
    PluginAPI
        Win32 Version: 1.0.0.0
        CodeBase: file:///C:/Program%20Files%20(x86)/SimTools/PluginAPI.DLL
    LiveForSpeed_Plugin
        Assembly Version: 1.0.1.1
        Win32 Version: 1.0.1.1
        CodeBase: file:///C:/Users/e/AppData/Local/SimTools/GamePlugins/LiveForSpeed_Plugin.dll
    RichardBurnsRally_Plugin
        Assembly Version: 3.0.0.4
        Win32 Version: 3.0.0.4
        CodeBase: file:///C:/Users/e/AppData/Local/SimTools/GamePlugins/RichardBurnsRally_Plugin.dll
    enabled.
    For example:
    <configuration>
    </configuration>
    153,914Coins
    +11,154 / 57 / -2
    All of those software components are pretty old now, so it may be a compatibility issue. @value1 wrote the Sketchup tutorial so perhaps can shed some light on why the model disappears.
    What version of Windows are you using and is it X86 or X64?
  13. fzxj520
    1,341Coins
    I use win 8.1 x64
  14. SteVoortwis
    SteVoortwis New Member Gold Contributor
    Netherlands
    142Coins
    I had the same problem with sketchup 8. If you have 64 bit installed use a 32bit sketchup 2015 installation, because a 64bit does not recognize the plugin file sketchy physics. Download latest version of sketchy physics change zip file to rbz. Open google sketchup go to window - preferences - extansions - install exstansions open sketchy physics.rbz file. The plugin folder is in a different diractory. User/appdata/roaming/sketchup 2015 put your wackelstuhl files in it. And go!!
    • Informative Informative x 3
  15. fzxj520
    1,341Coins
    Two directory has copies of these two documents(Wackelstuhl.rb,socket.so).
    C:\Users\xxxxx\AppData\Roaming\SketchUp\SketchUp 2014\SketchUp\Plugins (SketchUp2014 legacy installation folder. If you installed SketchUp8 do not have this folder)
    D:\soft\Google\Google SketchUp 8\Plugins
    Probably because it does not support win8.1 x64. SteVoortwis you use win8.1 x64?
  16. SteVoortwis
    Netherlands
    142Coins
    I am using Win7 x64. I would suggest to use the latest Sketchup version and remove the old one. And use only the folder as i said before. The new version you don't need to install ruby. The newest version of Ruby is implemented in the latest sketchup.
