Newbie 2dof
Discussion in 'DIY Motion Simulator Projects' started by Kamatari, Jul 3, 2015.
  1. Kamatari
    Kamatari New Member
    434Coins
    Hi guys,
    Looking at doing my first attempt at 2dof although still a little lost but we shall see what happens!
    Slowly starting to build the frames and getting everything ready, going with arduinos and monster moto's although still undecided on the actual motor route, i was looking to go with wiper motors but not sure what are decent to get in the UK so im considering: 12V DC Geared Motor, Motor with 60:1 ratio Gearbox
    http://www.ebay.co.uk/itm/381299669893?_trksid=p2060353.m1438.l2649&ssPageName=STRK:MEBIDX:IT
    From Motion Control Products
    Although a quick question about the motors (or in general?) with the potentiometers, would i need to drill the shaft to mount the pots to, or would you be mounting them on the same side that the arm would be going to?
    Update 8/7/15
    Motors, power supply, arduino and monster moto ordered, I think due to the motors I've gone with now, i might be best ordering a second MM
    Started building the race frame, for now it is being built out of wood and for the seat I will be using one of my old rx7 seats for now, terrible build picture time :
    Update 13/7/15
    Not done much yet and still waiting on motors, order second MM and power supply, picked up a propshaft locally for a tenner.
    So far the seat is now mounted to the frame meaning the only main thing to do is to sort the steering wheel mount
    153,794Coins
    +11,150 / 57 / -2
  3. Kamatari
    Kamatari New Member
    434Coins
    Basically aslong as the pot is attached to the moving part it should be ok :)
    Has anyone got any suggestions on motors (i know it gets asked), seems like decent looking wiper motors end up costing nearly as much as the ones I linked, just wondering if it's worth finding some cheap wiper motors or spending the money
  4. paulg100
    paulg100 Active Member
    Bristol UK
    1,373Coins
    3DOF, DC motor, 6DOF
    id grab some of those motors whilst you have the chance.
  5. Kamatari
    Kamatari New Member
    434Coins
    Advice taken and ordered :)
  6. Edson Lourenço Bezerra
    Edson Lourenço Bezerra Edson Bezerra - Desenvolvedor Open Source
    Analista de Sistema
    Jundiaí
    147Coins
    2DOF, 3DOF, DC motor, Arduino, Motion platform, 4DOF
    Greetings, there is a CHANCE of use of gears
  7. WhiteGoblin
    WhiteGoblin Member
    California
    549Coins
    I second grabbing those motors. I've PMed the seller to see shipping costs to the US, so consider yourself lucky.
  8. Edson Lourenço Bezerra
    Analista de Sistema
    Jundiaí
    147Coins
    Mr. greetings WhiteGoblin
    WhiteGoblin, what the size of your platform?
    I use actuator motors for wipers caminhãos of the windshield. THE have the same with a reduction gear which can provide greater strength and torque required for movement.
    hug
  9. Kamatari
    Kamatari New Member
    434Coins
    Grabbed the left and right motor :) maybe I've held someone out by posting the link :)
  10. paulg100
    Bristol UK
    1,373Coins
    you did, i grabbed another for eventual traction loss.
    Last 2 i bought were at xmas and have been out of stock since so dont come up often.
  11. Kamatari
    Kamatari New Member
    434Coins
    Aha tempting but ill stick with the original plan for now :)
    I will be updating the original post with new info
  12. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    Hi @Kamatari I would advise you use a second MM one per motor at least (I've got the same motors and have used them with both MMs and JRKs )MMs there seems to be a lot of faulty ones on the market at the moment so I would test they are ok before so you don't get confused thinking the problem is software related good luck with your project:thumbs
    Also where are you located in the uk ?
  13. Kamatari
    Kamatari New Member
    434Coins
    I think if I was going the wiper route I might have got away with one MM but with these motors I was thinking it might be best for one per, so I shall follow the advice (and hope that the MM's are good)
    I'm located in birmingham :)
  14. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    So far you have do the same as me I started the same way one MM with wipers then better motors with two all before even finishing the project lol gota love upgrades
  15. Kamatari
    Kamatari New Member
    434Coins
    The plan was to try and keep the cost down but trying to find some decent motors, just seemed worth spending the little bit extra
  16. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    Lol same, if they've not turned up yet wait till u see the size of them compared to wiper motors made me chuckle :grin
  17. Kamatari
    Kamatari New Member
    434Coins
    Maybe they are going to be bigger than expected :eek:
    What did you use for your pivot point?
  18. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    End of a prop shaft (universal joint)
  19. Kamatari
    Kamatari New Member
    434Coins
    Guessing that would be the case, anywhere/thing in particular to get?
    I'm hoping my build thread will help others as I haven't got a clue really so will be amazed if it works :)
  20. Daguru
    Kitchen installer
    Wales uk
    233Coins
    Motion platform
    I went to a prop shaft company local to me and asked for the universal joint end with about 400mm of pipe still attached charged me £20 I was more than happy as the nearest car breakers a lot further away and saved me time :thumbs
    my build thread if you wana take a look
    http://www.xsimulator.net/community/threads/diy-2dof.6083/
