h-bridge 12v 40amps
Discussion in 'SimTools compatible interfaces' started by trust928, Sep 19, 2013.
  1. trust928
    trust928 Member
    brazil
    435Coins
    thanks im finishing my one, im building 2 small circuit in one pcb i will post pics as soon as i finished, and in the end of the all work i will put all the steps on first page..
  2. prilad
    Dubna, Russia
    9,664Coins
    3DOF, DC motor, Arduino, 4DOF
    At schematics with digital chips VCC and GND wires are connected to chips by default. These wires are usually not drawn.
  3. trust928
    trust928 Member
    brazil
    435Coins
    as i promissed here are the pics of the small circuit.. it has 2 circuits in on board to make things more easy..
    can i join all the vcc of the 2 circuits in one sigle wire? and the GNDS?
    IF IM GOING TO USE AN EXTERNAL 5+ POWER IT HAS ONLY positive and negative.. theres no GND
    can i plug the negative in place of the GNDS?
    can arduino 5vcc and gnds handle this 2 circuits?
    thanks to all
  4. prilad
    Dubna, Russia
    9,664Coins
    YES
    YES
  5. trust928
    trust928 Member
    brazil
    435Coins
    thanks prilad.. i thinks it will work good, and will be an alternative to who wants an easy high power h-bridge...
    i will post some videos later
  6. trust928
    trust928 Member
    brazil
    435Coins
    I'm having some problems soon as i finish i all be updating the tread
  7. RacingMat
    21,067Coins
    Hi @trust928 !
    What's new? Did you achieve your goal?
  8. trust928
    trust928 Member
    brazil
    435Coins
    hey racicing mat.. ive not achievet yet.. im missing some isolator coz my h-bridges are conflicting with my computer. and they burn every time that its happens... i dont knowww yet how to solve it
  9. Historiker
    9,214Coins
    Trust! Good to see you back on the forums, sorry to hear that you are still having troubles. Perhaps it is time to buy a commercial product?
  10. trust928
    trust928 Member
    brazil
    435Coins
    its because here in brazil dont have the eletronics parts that i need.. so i did want to build all the eletronics.. but how to overcome the isolatorS? this is being my problem i think i will need to import the rest of the parts
  11. trust928
    trust928 Member
    brazil
    435Coins
    Hey guys im back, almost finished, im gonna post some pictures later, i found some 4n25 to isolate the ard from the h-bridge so i need a little help
    Ard---optocoupler--pcb---h-bridge
    My question is what resistor should i use with the 4n25 input and output?
    The last time without the optocoupler my h-bridge burned coz the software crashe wih the large amp of the motor trought ard so guys always use galvanic isolator lool
  12. Edson Lourenço Bezerra
    Edson Lourenço Bezerra Edson Bezerra - Desenvolvedor Open Source
    Analista de Sistema
    Jundiaí
    147Coins
    2DOF, 3DOF, DC motor, Arduino, Motion platform, 4DOF
    Greetings everyone.
    Well I am also in Brazil and really is quite complicated to find all components or people who esejam the willingness or interest to hear from you.
    But for future needs incargo have good contacts here in Sao Paulo and we can find almost everything.
    Hug.
  13. trust928
    trust928 Member
    brazil
    435Coins
    hi edson i have sent u an email, its not very easy, but its not impossible, ive got my working after a lot of enforts and still needs a lots of adjustes, i will be in sao paulo so soon,,, keep in contact cheers
  14. Rohith
    Rohith New Member
    17Coins
    Hi, I am working on a load of DC 12V, 40A. I am having a trouble in designing H bridge for it. I need your help in that. Can you please send me the circuit for 12v 40A.
  15. BlazinH
    16,676Coins
  16. zapata_h
    zapata_h Active Member
    España
    308Coins
    3DOF, AC motor, Arduino
    As Comrade BlazinH says, take a look at that link, bridge at a very good price
