My simulator 2dof for ps3 and pc
Discussion in 'DIY Motion Simulator Projects' started by Andrea 1968, Jul 2, 2015.
  1. Andrea 1968
    Andrea 1968 Member
    italia
    193Coins
    ecco il mio simulatore a due assi compatibile con tutti i giochi ps3 e pc.
    i dati vengono presi direttamente dalla periferica volante e pedaliera.
    motori passopasso 24v 6A
    hardware due schede arduino
    due stepper drive 5-6A
    Non posso postare video perche' sono nuovo ma presto lo faro'.
    intanto allego qualche foto.
    here's my two-axis simulator compatible with all PC and PS3 games .
    the data is taken directly from the device steering wheel and pedals .
    stepper motors 24v 6A
    two boards Arduino hardware
    two stepper drive 5-6A
    I can not post video 'cause I'm new but soon I will ' .
    Meanwhile I enclose a few photos
    153,703Coins
    Thanks for posting the description and photos, it certainly is a unique rig you have there. I will be looking forward to seeing the video to see it in action.
    Grazie per aver postato la descrizione e le foto, è certamente un impianto unico che hai lì. Sarò curioso di vedere il video per vederlo in azione.
  3. GTHQ_koop
    GTHQ_koop Active Member
    Something with airplanes..
    Lakehills Texas USA
    1,786Coins
    2DOF, SCN5
    Very nice :)
    Does it also work on PS4..?
  4. Wanegain
    Wanegain Active Member
    Bruxelles
    2,017Coins
    It certainly works but it can't be realistic...
    I tried this method when no plugin was available and sometimes the movements were very strange compared to what you see on screen.
    But I realy like the idea and I hope see a video soon :thumbs
  5. Andrea 1968
    Andrea 1968 Member
    italia
    193Coins
    It includes photos and control commands
    the pressure gauge is used to the pressure of the compressor under the seat to replicate the breath valve turbo when changing gears.
    Within the two tubes blacks reside two woofer 50 watts and two tweeters for audio and concrete ballast to balance the weight of the rider to lighten the engine work.
    the audio amplifier and 'placed before the pedal.
    I can assure you that calls for a lot especially when changing gear or scale (after 20 minutes of back pain !!! :(
  6. Andrea 1968
    Andrea 1968 Member
    italia
    193Coins
