Lesson chaos wiring?
Discussion in 'Electronic and hardware generally' started by Pit, Feb 7, 2015.
  1. Pit
    30,510Coins
    If YOU think, you have all under control, in this case you can miss this thread. If your wiring looks like the picture below:
    you should have this:
    or this:
    or this:
    If YOU do not know, what it is - it is called a
    BREADBOARD
    http://en.wikipedia.org/wiki/Breadboard
    Happy building!
  2. bsft
    OCD, OCD OCD!!!!!
    (obsessive compulsive disorder)
    :grin
  3. fzxj520
    fzxj520 Active Member
    1,341Coins
    Good idea! Already on my shopping list :cheers
  4. christian
    christian Member
    Germany/München
    967Coins
    2DOF, SCN5, SimforceGT
  5. RacingMat
    21,081Coins
  6. xStouf
    xStouf New Member
    544Coins
    Arduino, 6DOF
    What a nice wiring, very clear and so easy to sort :D
    Now, find this short !
  7. Ben V
    Ben V Member
    Alberta, Canada
    181Coins
    As a professional Electrician, I've become a big fan of a product we call wire ducting. It's available in a wide variety of colors and sizes to suit the job at hand.
    Most wires can just be routed out the slots already in the sides. For larger wire sizes, the "tabs" can be snapped off quite easily if you flex them to the outside. I usually leave a little bit of extra wire in a zig-zag shape inside the ducting, so if you want to move a wire to a different terminal later on, you don't have to extend or shorten it.
    Here are a couple examples of panels I've done with wire ducting:
    PLCs in a control cabinet.
    12V & 120V Marine style breaker panel interconnects
    • Useful Useful x 4
  8. xStouf
    xStouf New Member
    544Coins
    Arduino, 6DOF
    This is very usefull, thank you for the tip !
  9. Alexey
    Alexey Well-Known Member
    Electronics Technician
    Adelaide, Australia
    8,066Coins
    Neat, cheap, effective.
    Self adhesive sticky tie bases and cable ties.
  10. Gabriel Vuelma Romanzini
    Gabriel Vuelma Romanzini Member
    SolidWorks User
    Nova Prata - Brasil
    558Coins
  11. Gabriel Vuelma Romanzini
    SolidWorks User
    Nova Prata - Brasil
    558Coins
  12. tombo
    tombo Active Member
    1,969Coins
    DC motor, Arduino
    For my finished cables I always use this
    I don't know the name. But it's wrapped around cables in automobiles and it gives a very good look.
    Here is a picture of two cables I made with this. (make shure to inlarge so you can zoom in ;))
    For me the Breadboard didn't help to reduce the wiremess :p
    • Funny Funny x 2
  13. Gabriel Vuelma Romanzini
    SolidWorks User
    Nova Prata - Brasil
    558Coins
    Other simple tip that almost all already know is to use:
    That Helps a lot :)
    And if you don't have it you can pass a insulating tape around the wires...
    To isolate you can also use Heat Shrink tubing:
  14. Oz_gadget
    Oz_gadget New Member
    retired
    Melbourne, Australia
    243Coins
    Arduino, Joyrider, Motion platform, 6DOF
    I spent many years in data centres doing cable management on server racks
    always preferred building a rack myself 'greenfield' rather than working on trying to unf@#k someone elses catastrophe, some of the most otherwise diligent and intelligent sysadmins would somehow lose all common sense when physically racking a server...
    I always staged any cabling with double-sided velcro tape, similar to this stuff
    https://www.aliexpress.com/item/400...chweb0_0,searchweb201602_6,searchweb201603_52
    it comes in a range of widths, 2"/50mm, 1"/25mm or even narrower ~10mm & 5mm
    the smaller stuff is great for doing thinner cables and small runs.
    the wider stuff will obviously hold together better and helps keep a linear direction as well
    its more expensive than buying cable ties, but cheaper in the long run as you can reuse.
    this stuff is excellent for staging/preparing your cable runs, flexible in allowing quick changing of runs and robust enough to leave in place once finalised.
  15. dododge
    dododge Active Member Gold Contributor
    854Coins
    For bundling cables I'm a big fan of "Flexo F6". Pretty much the only downside is that you have to heat-seal any cuts you make to keep them from fraying. A hot knife makes that easy if you've got one handy, and I've managed to use a lighter as well.
    The bundles can then be strapped down with velcro ties as needed.
