Resolved Game Engine Exceptions
Discussion in 'SimTools DIY Version' started by natureYtf, Jul 10, 2015.
  1. natureYtf
    natureYtf Member
    student
    China
    594Coins
    I want to test the data from Live For Speed ,So I use Virtual Axis output testing,but when I start driving,the slider moves randomly and Game Engine just throw an exception blow:
    System.OverflowException: Arithmetic operation resulted in an overflow.
    at SimTools_GameEngine.frm_GameEngine.tmr_VirtualAxes_Tick(Object sender, EventArgs e)
    at System.Windows.Forms.Timer.OnTick(EventArgs e)
    at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
  2. natureYtf
    natureYtf Member
    student
    China
    594Coins
    Were my settings wrong ? If they were ,thanks for pointing out!
  3. eaorobbie
    20,481Coins
    mmm Can not see what bitrange you are using, please fix your DPI settings in windows needs to be run at 100%
    Not setting there could be creating the error.
    My question , Net output ??? what controller are you using ?
  4. natureYtf
    natureYtf Member
    student
    China
    594Coins
    I am using bitrange of 8.I'm going to use SCN6,but my SCN6 hasn't arrived yet ,so I want to be familiar with SimTools before it arrived.So I just use virtual
    axis to test the data from LFS .I saw from the
    "How to write a Plugin for SimTools - API documentation"
    that LFS export telemetry data via UDP packets,so I set a net output.Is this wrong?But how to correct it.
  5. natureYtf
    natureYtf Member
    student
    China
    594Coins
    My DPI setting in window is 100%,but the character just shows like that in the UI of SimTools.
  6. value1
    15,032Coins
    Try another port than 4123. This port is used by SimTools for LFS.
  7. yobuddy
    51,030Coins
    Yes, @value1 is correct.
    I'll have to try this here and fix the bug, thx!
  8. eaorobbie
    20,481Coins
    For SCN5 use you don't set the interface to NET, Its SCN.
    For testing SimTools and to use the virtual axis to see the data from LFS you actually don't need to set any interfaces at all.
    Just set the default axis assignments and copy that to the LFS Axis Assignments, Patch the Game with the Game Manager and start the game.
    Click on to the Virtual Axis and now the information will be shown on the sliders when on track in the game.
    I think you were misunderstanding that SimTools needs to be setup to read the values LFS is exporting, that happen in the background for you , The Magic of SimTools.
  9. natureYtf
    natureYtf Member
    student
    China
    594Coins
    @eaorobbie,I followed your steps to not set any interfaces,but when i run LFS ,the slider of virtual axis didn't move at all.
  10. value1
    15,032Coins
    Ok, if you only want to have a play with SimTools do this:
    Start GameManager and GameEngine
    In GameManager patch the game (LFS)
    In GameEngine copy exactly these settings:
    Take *any* COM-port you find. It doesn't matter.
    Interface - Output shall read: <221><Axis1><Axis2><Axis3><Axis4><Axis5><Axis6>
    The switch to the VirtualAxis tab Output Testing and click Turn On
    You can also open the Tuning Centre via the taskbar
    And watch what happens
  11. natureYtf
    natureYtf Member
    student
    China
    594Coins
    @value1 ,I download the latest version of LFS,and follow your settings,the slider didn't move at all.but if I change LFS to my old versions,and also your settings exactly,it's strange that the slider moves randomly.What is wrong.I am going crazy.
  12. value1
    15,032Coins
    After you installed the latest version, did you unpatch and re-patch the game?
  13. value1
    15,032Coins
    And what are your Max/Min settings in Tuning Centre?
    The lower the more vibration (or "random" movement) you will see.
    LFS outputs "random" data even when your car is standing. There is always a minimum vibration when the engine is running.
  14. natureYtf
    natureYtf Member
    student
    China
    594Coins
    I repatch the LFS,but I didn't set anything in the tuning center.
  15. natureYtf
    natureYtf Member
    student
    China
    594Coins
    this is a capture of the tuning center UI when I run LFS.
  16. natureYtf
    natureYtf Member
    student
    China
    594Coins
    Every time the slider moves,it must move to the left or to the right.Even when my car stand.And then the game engine throws an exception.If I don't turn on the virtual axis,the tuning center has input but if then I set on the virtual axis the exception occurs.And I capture a pitch of 1.94499E40,and many numbers like that.
  17. value1
    15,032Coins
    @natureYtf: Can you upload your cfg.txt which you find in the LiveForSpeed directory (e.g. c:\lfs\)
    Thx.
  18. natureYtf
    natureYtf Member
    student
    China
    594Coins
    I capture a pitch of 1.94499E40,and many numbers like that.My cfg.txt file is here,thanks a lot.@value1
    • cfg.txt
      3.2 KB
      1,136
  19. value1
    15,032Coins
    Hmm, I tend to think it has to do with your local (Chinese) settings. The files is patched correctly so it should move correctly.
    I'm on the road. Will see if I can send you some instructions later.
  20. value1
    15,032Coins
    Try, if setting the decimal separator to "." rather than anything else (in Windows language/country settings)
