First attempt at a 2DOF motion sim
Discussion in 'DIY Motion Simulator Projects' started by SilentChill, Jul 24, 2014.
  1. SilentChill
    20,601Coins
    Good by my first born sim may you rock away in sim heaven
    153,824Coins
    +11,151 / 57 / -2
    At least you have the numerous videos to remember it by and I suspect those will continue to draw newbies to Xsimulator.net for some time to come.
  3. nachofly
    nachofly New Member
    274Coins
    yup, i found them really awesome bran new shinny super motors...1200 bucks each... so yeah... no bueno for me.
  4. Agosky
    Agosky New Member SimAxe Beta Tester Gold Contributor
    Finland
    307Coins
    Wow, that is/was a sweet rig @SilentChill!
    One question: How did you set up traction loss axis in Simtools for RBR, as game plugin does not support it directly?
  5. SilentChill
    20,601Coins
    I honestly cant remember , is there no extra axis ?
    153,824Coins
    +11,151 / 57 / -2
    By all means post in your native language @cabexaz but please do also include an English translation via Google Translate. It saves other members time trying to work out who may need help and who is just posting a comment.
    We have bi-lingual speakers from many different language group so if Google Translate really messes it up they can help clarify what was intended.
    There is a specific section for native language based social interactions: http://www.xsimulator.net/community/#international-social-chats-and-conversations.155
  7. mariano68
    mariano68 Active Member
    builder contractor
    Argentina
    3,340Coins
    2DOF, Arduino, 4DOF
    Si es solo para montaña rusa, creo que tendrias que ponerte a leer sobre simuladores tipo "joyriders" http://www.xsimulator.net/joyrider-motion-simulator/ que a mi parecer seria lo que mejor sensación te va a dar.
    El resto es todo lo mismo, Sintools soporta No limits 2 y con eso tienes para hacer las rollercoasters que quieras.
    If you only want to ride rollercoasters, I think a joyrider sim type will fit your needs best. Simtools has support for "No limits 2" and you can do any rollercoaster with that prog.
    153,824Coins
    +11,151 / 57 / -2
  9. cabexaz
    cabexaz cabexaz colombia
    profesor
    Calima
    180Coins
    2DOF, 3DOF, DC motor, Arduino, Joyrider, SimforceGT, Motion platform, 4DOF, 6DOF
    you can tell me what function the center engine and how it connects
  10. cabexaz
    profesor
    Calima
    180Coins
    I find just as do the connection of 2 engines
  11. mariano68
    builder contractor
    Argentina
    3,340Coins
    2DOF, Arduino, 4DOF
    That's for traction loss
    Sorry @SilentChill , I don't want to bother in your thread, I really like your old sim :)
  12. Sebj
    Sebj Active Member
    Canada
    492Coins
    @SilentChill , Fanastic build of the 3DOF rig.
    Been watching your videos, you have them setup to move quite a bit with the DK2, do you every get motion sick?
  13. SilentChill
    20,601Coins
    @Sebj I dont suffer from any motion sickness at all so no its all good
  14. helisfreak
    helisfreak Member
    Phoenix, AZ
    591Coins
    Hi, where can I download the full res of the wiring diagram? thank you.
  15. Jamburglar
    Jamburglar Member Gold Contributor
    Controls Engineer / Software Engineer
    Michigan
    186Coins
    @SilentChill I am going to shamelessly rip off this design. It looks amazing. You don't mind, do you? Any lessons learned? Suggestions? Still looking for good motors. Ordered mm and have ard for testing.
  16. SilentChill
    20,601Coins
    This was an easy easy straight forward build. Nothing really too taxing to be honest. As long as you get your COG right you shouldnt have any problems.
  17. Jamburglar
    Michigan
    186Coins
    I just snagged some motors. @Pit seems to think they're too fast. We will see. Keeping fingers crossed.
    http://www.ebay.com/itm/351158629824
  18. Pit
    30,510Coins
    Already commented in your thread: "60-80RPM would be fine, if you have to reduce the speed you have to reduce the power, that means you have less torque at least."
  19. Playsimulator
    Playsimulator Member Gold Contributor
    france la voulte sur rhone
    178Coins
    3DOF, Arduino
  20. Pedro Silva
    Pedro Silva New Member
    Telecomm, Electronics
    Yoshkar-Ola, Russia
    251Coins
    Hi @SilentChill !
    I know it may be way too late to go back with this given your advanced stage on your 6DoF, but i must ask you couple things about your 3DoF cause thats the kind i chose to be my first project... Im sorry if the answers are in your thread, but i couldnt find going thru the 7 pages... Here we go:
    1) Did you use @eaorobbie 2DoF RC model Arduino code in your project, or @RufusDufus tools? Or any of them? If any, is it possible to share the final code you used in your 3DoF?
    2) Could you post the screenshot of your axis assignment, interface settings and tuning of SimTools that you used for NoLimits Rollercoaster?
    3) If you had to built it all over again, would you flip to metal frames and bases or would still use wood like you did?
    Thanks and cheers!!
