Showroom DX - Compact Simulator
Discussion in 'DIY Motion Simulator Projects' started by noorbeast, Sep 29, 2014.
  1. noorbeast
    152,676Coins
    +11,089 / 56 / -2
    Yes if you recall I asked you about the balls screws @SeatTime, as a potential solution. I think I will go that way in future, both for the efficiency gain, unpowered holding capacity which I think you said was around 70kg and likely much better capacity to take constant high torque reversals.
    Yep I will suck and see how the approaches I have taken to addressing the same issues you have picked up on go in actual practice @bsft.
  2. SeatTime
    Yes, its all really academic, as the BK bearing that supports it is only good to 153Kg dynamic (yes I did finally find the data).
    152,676Coins
    +11,089 / 56 / -2
    I wired up the JRKs today. If I can get some time tomorrow I can throw it all back together and test some movement.
    The wiring box the three JRKs sit on also houses the Arduino and two BECs for the surge table underneath, with the fuse box on one end. It looks a bit of a mess at the moment as there is a fair bit of cable management still to come, some of which hinges on how I decide to do the HOTAS and control box mounts. I am still playing with some different options there.
    Can any of you Aussie RC fans recommend a supplier for these ball posts? I broke one when removing it from the surge plate.
  4. SeatTime
    Hi @noorbeast . Maybe for your information In regard to the load bearing on those 60:1 etc gearboxes - something I found the other day on the Motion Dynamics site when I went looking for a new 24V motor (not easy to find).
    Note, while the motors and high ratio gearboxes are capable of great torque (up to 75nM in 320W) run times greater than an hour/day with torque over 40nM or loads exceeding 65nM for more than 1-3 minutes are not recommended for any sort of gearbox longevity. They can handle great torque for short bursts, but not for extended periods. If you require higher torque for longer periods, please look at the heavy industrial range of motors and gearboxes which are rated to run higher torque for longer periods.
    152,676Coins
    +11,089 / 56 / -2
    Interesting @SeatTime, do you have the link where that can be found?
  6. SeatTime
    152,676Coins
    +11,089 / 56 / -2
    There is always Murphy's Law and I have been caught out with this one in the past where the USB cage on a brand new JRK is not properly attached to the board. I have notified the supplier and am waiting on a response.
  8. bsft
    I usually hear back from Pololu within 24 hrs of an email. So maybe they are ignoring you.
    152,676Coins
    +11,089 / 56 / -2
    I notified the Aussie supplier this morning @bsft once I did the video so it was clear what the issue is. I have found direct dealings with Pololu in the past have been pretty good.
  10. GIB SimRacing
    GIB SimRacing Active Member
    Barossa Valley, SA
    983Coins
    Hah, I never thought to look at this. I am hunting down a gremlin in my system atm. Definitely have to have a look at the USB port on the JRK's...
    152,676Coins
    +11,089 / 56 / -2
    The first time I struck this it was really difficult to pick as the JRKs were mounted under the fan inside the frame and you could not observe the LEDs.
    The other thing is that vibration can either keep the usb connected for a while, or keep it from connecting, which is a real pain of a gremlin as it is inconsistent and as per the video it only takes a small amount of pressure one way or the other.
  12. speedy
    speedy Well-Known Member
    Alexandria , Egypt
    7,944Coins
    Is it a dry solder in the USB ?
  13. noorbeast
    152,676Coins
    +11,089 / 56 / -2
    Not that I can see, the cage looks OK so I am guessing it is the pins, it only takes slight pressure to alter the contact.
  14. bsft
    Hang on, you got them from Aussie supplier right?
    Interesting that I have NEVER HAD A PROBLEM ordering direct from Pololu.
    Case closed
    152,676Coins
    +11,089 / 56 / -2
    I have struck the same problem before with a JRK from Pololu, more likely it is a batch issue.
    I have actually been pretty impressed with the rapid responses from Peter Simmonds at the Aussie supplier Ocean Controls. Peter was happy for the JRK to be returned and a full refund being given on verification. Peter also offered to repair it, but I did not want to do so, both because of time and possible quality implications.
  16. bsft
    152,676Coins
    +11,089 / 56 / -2
    Some slow progress. I upgraded the motherboard for the sim computer.
    I was not really happy with the mount for the 3 JRKs so I made up a new box to replace it...much neater. I just need to notch the surge plate a little more tomorrow to fit the fan and billet cover. The new box also houses the Arduino under the JRK mount plate and the fan speed and LED controls on the front. Air exits out of 2 alloy plates facing the inside of the sim.
    3.jpg The original mount was messy.
    IMG_20150727_130231.jpg The new box is much neater and can be unplugged as a unit for servicing.
    IMG_20150727_215613.jpg The fan speed control and LED light change switches are accessible on the front outside face of the housing.
    IMG_20150727_215904.jpg Air exits toward the inside.
    • Like Like x 5
  18. WowaDriver
    WowaDriver Waldemar Jost
    Bachelor of Science and Engineering
    Hannover
    1,127Coins
    You are a great and compact designer :D ... i think i somebody who doesn't know that your construct is a sim, may think that will be a emergency seat of a real jet or something :D
  19. GIB SimRacing
    Barossa Valley, SA
    983Coins
    As always, very impressive work @noorbeast. I know building compact AND aesthetically pleasing can be very challenging! Looks like you got it sorted though.:thumbs
    152,676Coins
    +11,089 / 56 / -2
    Thanks all for the encouragement.
    The other bit I am focusing on is serviceability.
    To make getting the control box in and out as a unit a bit easier the JRK USB hub has been relocated today, with a 2 part cover made for the left hand side of the sim base, which makes it easier to place the wiring loom inside the limited space of the sim base frame. The 500x500 base frame houses 3 PSUs, 2 USB hubs, an amp and subwoofer down the middle, plus the Fanatec power supply, so there is only a small space for the wiring loom and snap in loom connectors.
