Driveshaft
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Sebj, Jul 18, 2015.
  1. Sebj
    Sebj Active Member
    Canada
    492Coins
    Will this be adequate for a driveshaft(u-joint), its made of aluminium.
    or this?
  2. cthiggin
    cthiggin Active Member
    Self-Employed
    Montgomery AL USA
    15,210Coins
    Aluminum takes more skill to weld............plus if you're going to try and weld to a "steel plate", ALMOST un-doable even in professional welder hands.
    Steel is the best way to go for the u-joint.
  3. Sebj
    Sebj Active Member
    Canada
    492Coins
    Thanks @cthiggin ...I'm not expert hence asked and appreciate the advice.
  4. bsft
    Are you planning to cut and weld?
    Tailshaft is the preferred option of course, but unless you have aluminium welding gear, forget it. Hunt up a steel one.
    The steering knuckle would do the job for a seat mover though.
  5. momoclic
    momoclic Active Member
    Retraité
    Nantes - France
    2,773Coins
    DC motor, Arduino
  6. bsft
    ok good luck then
  7. bruce stephen
    general contractor
    michigan
    9,115Coins
    imho seems like a lot of extra work and more money. I agree steel being the easiest route.
  8. cthiggin
    Self-Employed
    Montgomery AL USA
    15,210Coins
    Steel is "the deal"...........and as stated, will really reduce your workload and end results = Same. IMHO
