Salut à tous
Discussion in 'New users start here - FAQ' started by Roman, Jul 18, 2015.
  1. Roman
    Roman Member
    366Coins
    2DOF, DC motor, Motion platform
    Salut à tous,
    je me suis déjà presented in the rubrique "français" mais Apparemment qu' il faut le faire, alors je recommence.
    J'ai 47 ans et suis en France, Dans l'Essonne. J'ai fabriqué un simulateur dynamique avec deux moteurs Smolka 24V , une carte Arduino, une Saber 2x25. J'utilisais X-Sim et souhaiterais passer sur Simtools.
  2. Roman
    Roman Member
    366Coins
    Pour poster une photo, y a t'il un format particulier ?
    153,758Coins
    Google Translate -
    Hi all, I am already presented in the section "French" but apparently that it must be done, so I'm recommence.J'ai 47 years in France, in the Essonne. I made a dynamic simulator with two 24V motors Smolka, an Arduino board, a Saber 2x25. I used X-Sim and would go on Simtools.
    Google Translate -
    To post a picture, there is there a particular format?
    Welcome @Roman.
    I think you will find SimTools to be highly responsive and pretty easy to configure and use. The best part is that there is also a very active community here who are always willing to help out.
    Unfortunately there are limitations for new members until they have made 5 posts, to prevent spam, see here for details: http://www.xsimulator.net/community...ed-posts-needed-before-links-can-be-used.150/
    Posting pictures is easy: http://www.xsimulator.net/community/faq/upload-pictures-or-files.81/
    In the main threads by all means post in your native language, but please do also include an English translation via Google Translate. It saves other members time trying to work out who may need help and who is just posting a comment.
    We have bi-lingual speakers from many different language group so if Google Translate really messes it up they can help clarify what was intended.
  4. Roman
    Roman Member
    366Coins
    IMG_2318.jpg IMG_2309.jpg 01b9dd9ed07d21d7cd286879adef162a86c9108c55.jpg Bon des Photos de mon simu:
  5. Roman
    Roman Member
    366Coins
  6. Roman
    Roman Member
    366Coins
    Est ce quelqu'un a testé Project Cars?
  7. Roman
    Roman Member
    366Coins
    Existe il un plugin pour ce jeu?
    153,758Coins
    Google Translate -
    Is someone tested Project Cars?
    Google Translate -
    Is there a plugin for this game?
    Yes there is a ProjectCars plugin: http://www.xsimulator.net/community/marketplace/pcars2-plugin.147/
    There are people regularly using the plugin and you can check the version history and discussions about the ProjectCars plugin on the labeled tabs on that page.
    As per earlier advice please do post in your native language, but as a courtesy do also include an English translation via Google Translate. It saves other members time trying to work out who may need help and who is just posting a comment.
    We have bi-lingual speakers from many different language group so if Google Translate really messes it up they can help clarify what was intended. @RacingMat and @Wanegain are just 2 of the many active and knowledgeable members who may help out if language is a barrier.
  9. Roman
    Roman Member
    366Coins
    Merci, je vais regarder.
  10. Wanegain
    Wanegain Active Member
    Bruxelles
    2,018Coins
    Comme suggéré par @noorbeast tu devrais écrire en français puis mettre la traduction en anglais (faite par google translate par exemple) pour que tout le monde puisse te répondre. Même si la traduction n'est pas parfaite.
    Google Translate : As suggested by noorbeast you should write in French and then to the English translation (made by google translate for example) so that everyone can answer you. Even if the translation is not perfect.
  11. Roman
    Roman Member
    366Coins
    Maintenant j'ai pointer le bon chemin et ça fonctionne presque.
    J'ai les effets latéraux mais pas longitudinaux o_O
    Now I have to point the right way and it almost works .
    I have the side effects but not longitudinalo_O
    153,758Coins
    Could you please post screen shots of your settings for SimTool and the Tuning Center.
    Have you done a base setting for the Tuning Center: http://www.xsimulator.net/community/faq/set-base-tuning-motion-values-in-the-tuning-center.122/
    As an example here is @prodigy's Project Cars settings, note the comment that the bigger the number in the Tuning Center the less powerful the force effect and do keep in mind each sim is different and the motion profile must be tailored to suit: http://www.xsimulator.net/community...sabertooth-moteur-essui-glace-24v.6387/page-2
  13. Wanegain
    Bruxelles
    2,018Coins
    You probably need to check the Dir checkbox for some Axis
  14. Roman
    Roman Member
    366Coins
  15. Roman
    Roman Member
    366Coins
    Bon, j'ai trouvé pour l'axe qui ne fonctionnait.
    Dans "Axis Assignments" "Game Defaut" j'ai rempli les champs et sauvegarder.:thumbs
    Roll, Pitch, Sway et Surge fonctionnent très bien quand je teste dans "Output Testing".
    Mais dans un jeu j'ai très peu d'effets d’accélération et de freinage o_O
    L'effet latéral fonctionne bien.
    Well, I found the axis that worked.
    In " Axis Assignments" "Game Default" I filled the fields and save . Thumbs
    Roll, Pitch , and Surge Sway work fine when I test in "Output Testing" .
    But in a game I have very little effects of acceleration and brakingo_O
    The side effect works well.
  16. value1
    14,236Coins
    You can play with the Max/Min settings in TuningCentre. The smaller the Max/Min settings the more motion you will have.
    153,758Coins
    Here is my earlier post regarding the Tuning Center: http://www.xsimulator.net/community/threads/salut-à-tous.7124/#post-82956
    Once you have a base profile tweak each force individually by manually adjusting the Min/Max for each force in the Tuning Center. When happy with each then turn them on and recheck what it feels like combined, as some forces like pitch and surge can have a cancelling effect on each other.
