Request (Feature) Why the rotations(pitch,yaw and roll)are angles in [°],not angular velocity
Discussion in 'SimTools DIY Version' started by natureYtf, Jul 22, 2015.
  1. natureYtf
    natureYtf Member
    student
    China
    594Coins
    I am wandering why the rotations(pitch,yaw and roll)are angles in [°],not angular velocity in[rad/s].
  2. bsft
  3. value1
    15,034Coins
    You're driving a hill up and want to feel the inclination the whole time.
    Or you drive on a banked curve. And you want to feel the tilt over rather whole curve not just at the beginning.
    That's why it's [°] not [°/s]
    Does this make sense?
    • Informative Informative x 3
  4. natureYtf
    natureYtf Member
    student
    China
    594Coins
    But some big angles cannot be simulated.How to solve it. @value1
  5. bsft
    What game are you playing to get that?
    have you tried just setting each force on its own and testing and adjusting till it feels ok?
    remember, its simulation and may not be 100% like the real thing
  6. SeatTime
    5 seconds on Google - See https://en.wikipedia.org/wiki/Aircraft_principal_axes . :rolleyes: You can only have 0 to 360 degrees...for pitch, yaw and roll. All angles can be simulated, just depends on your budget:). The actual velocity of the movement as you move from your current position to the new target position is dependent on what you simulation is doing (size of change) and the capability of your hardware to track that change.
  7. Mmcool
    Mmcool Member
    USA
    1,174Coins
    It makes sense to have these as forces so you can washout to initial position... Think of it...
    Mike
  8. RacingMat
    21,050Coins
  9. natureYtf
    natureYtf Member
    student
    China
    594Coins
    I mean which one is right, the value of roll ,pitch,etc is relatively to the previous value or absolute to an angle in a fixed proper position?
  10. value1
    15,034Coins
    Pitch, roll and yaw are absolute numbers and not relative to the previous value. So 180° will always point into the same direction.
  11. natureYtf
    natureYtf Member
    student
    China
    594Coins
  12. natureYtf
    natureYtf Member
    student
    China
    594Coins
    I want to make my own race game with unity,how should I calculate pitch ,roll,etc.The Unity provides a transform matrix,angular velocity and velocity. @value1
  13. RacingMat
    21,050Coins
    maybe we could add in the FAQ that angles are between -180° and +180°
    -180° < angle < +180°
    and what about forces? -oo < < +oo ?
  14. natureYtf
    natureYtf Member
    student
    China
    594Coins
    So the angles are absolute to every fixed coordinate system in the real world.Am I right?Or to only one coordinate system.
  15. value1
    15,034Coins
    The angles are relative to the local (vehicle) coordinate system. You can calculate the local angles from the transformation matrix. i.e. roll is always around the longitudinal axis of the vehicle, pitch around the lateral axis of the vehicle and yaw around the vertical axis of the vehicle.
  16. natureYtf
    natureYtf Member
    student
    China
    594Coins
    So ,if I know the angular velocity in the local coordinate system,I should calculate the integral of the angular velocity.Is that right?
