  1. SilentChill
    20,591Coins
    Quick video of Elite Dangerous , I know the motion needs a lot of tweaking :) Work in progress :D
    • Like Like x 5
    • Winner Winner x 3
  2. Leo Burton
    Leo Burton Active Member
    London, UK
    2,639Coins
    I can see what you mean. It does seem to need some more tuning, maybe some softening filters, but... MAN, that looks like a rush!!
    What forces have you dialled in so far?
  3. SilentChill
    20,591Coins
    All the 6 forces. I smoothed out too much as it was way too savage before . Takes a while to tweak each game spend more bloody time tweaking than playing
    Dirt Rally is so good though with all the forces you can feel everything
  4. Leo Burton
    London, UK
    2,639Coins
    So true! You can find yourself always chasing the perfect setup, and never get around to enjoying the game!
    • Agree Agree x 4
  5. Mamati
    Mamati Member
    Istanbul/Turkey
    158Coins
    @SilentChill I was planning to do the same rig with same configuration but I wasn't brave as much as you. You made a great job in a short period, I would like to really congratulate you! May I ask you 2 questions; could you please tell me the visual difference between Chinese MM and original sparkfun MM? When will you try it on No limits roller coaster on your 6dof? I will be waiting for it impatiently. Thank you.
  6. RacingMat
    21,047Coins
    you can see below the board
    "Sparkfun.com
    Monster Moto Shield"
  7. SilentChill
    20,591Coins
    Thanks @Mamati :)
    The chinese copies look the same and the clones just dont have the sparkfun on the back just monstermoto on them.
    I have tried nolimits but im really struggling for it to behave properly as the forces are not very good. Surge, heave and sway dont really seem to work on a 6DOF. I have tried different ways but it feels pretty shit to be honest, it was better on my 3DOF. It really really needs pitch and roll.
  8. mrbeginner
    What ever come in my way
    Finland Niinisalo
    - 10Coins
    I think i have the same problem in my motomonster. I change wiper motors because i believed they have some problem but the new motors work's same way. clockwise fast and counterclockwise they go about one circle very slow and stops. Mine motomonster was sparkfun text so it clone and after check there was gap under the chips. Where you buy those copy version?
    • Optimistic Optimistic x 1
  9. Alexey
    Alexey Well-Known Member
    Electronics Technician
    Adelaide, Australia
    8,066Coins
    You will find that it is the motors with the issue not the drivers, as wiper motors turn slower in reverse.
    In terms of the motor stopping in reverse, did you modify the power supply with resistors to bypass the safety override? If you haven't then the supply will give you a bit of current but will shutdown if the current draw goes over a certain limit. To get full current supply you must do the resistor modification. The reason why they would stop in reverse is because the motors actually draw more current in reverse due to the slant gearing in the wiper motor resisting reverse rotation due to friction. If the modification is not done the reversing of the motors might be tripping the supply.
    To confirm this simply connect your motors directly to the supply and hold your hand on the lever to make the motor work harder and draw more current. Do that in forward rotation and reverse rotation.
    To confirm that the drivers are faulty, simply switch the polarity on the motor and if the motors spin in reverse faster than spinning forward then it is the drivers.
  10. mrbeginner
    Finland Niinisalo
    - 10Coins
    Thanks for quick answer! Yes i know that the wiper motors work good only for one way. That's why i bought D63L motors in china 12v 45W and 55rpm with 20Nm. I try them with moto monster a1 - red wire and b1 - blue wire = clockwise ok . Then i changed a1 - blue wire and b1 - red wire then it goes counter clockwise ok. If i turn the position pot other way the motor turn slowly other direction and if i push the rod then the motor stop and red direction light onto moto monster shut down.
  11. bruce stephen
    general contractor
    michigan
    9,115Coins
    20150728_135151.jpg new motos from same seller are now just copies. the sparkfun ones i got looked better made. so i got 7 copies and only 1 doa. got refund in less than 24 hrs. the funny thing is even though these show up working they are cheaply made. a lot of the components are crooked and sloppy on the boards. 5 of the six working boards have a red power led and one has a green led. all the same tho. green led must have slipped into the pile. proof that QC is not a priority. In the end I'm just glad they work. we will see for how long tho.
  12. SilentChill
    20,591Coins
    Yeah these MM's are total hit and miss, Im glad I finally got 12 that worked. I still have 8 I just cant be arsed making video proof that they are all not working.
  13. RacingMat
    21,047Coins
    Hi ! could you please share a link? I didn't found any D63L motor on Aliexpres... nor eBay
  14. Wanegain
    Wanegain Active Member
    Bruxelles
    2,003Coins
    55rpm and 20Nm for 45W ?? o_O
  15. mrbeginner
    Finland Niinisalo
    - 10Coins
    http://wewinmotor.en.ecplaza.net/brush-dc-worm-gear-motor--309895-2379495.html
    DC Worm Gear Motor
    D63L(72)-12V45W-55RPM 4 pcs $220.00
    Freight cost $106.80
    TOTAL: $326.80
    These was for proto and after i get monster changed i try to send video that you can see how much they could move sim
  16. mrbeginner
    Finland Niinisalo
    - 10Coins
    Yes I know that sound too good to be true but what i tested it's has much more power than wiper motor.
  17. RacingMat
    21,047Coins
    have you measured the current under load by yourself? I bet it's over 4A
    4A x 12V = 45W
  18. mrbeginner
    Finland Niinisalo
    - 10Coins
    Good advice. I have now time to test because monsters are still somewhere in China. I put info after testing
  19. Alexey
    Adelaide, Australia
    8,066Coins
    That's actually about on par with commercial wiper motors. Don't forget it's only 55rpm.
    Examples: https://www.motiondynamics.com.au/domestic/ Usually the stats that suppliers give you
    are more of a baseline figure. The motors will definitely draw more than the rated wattage shown.
    My 200W (14A) motors would see spikes of 30A every now and then until I gave the sim more leverage.
    Also, might want to continue this discussion in your other thread as we are clogging up silentchills thread.
  20. mrbeginner
    Finland Niinisalo
    - 10Coins
    Good advise. i put the info for motors here:
    http://www.xsimulator.net/community...-2dof-is-better-than-no-movement-at-all.6809/
