value1
NoLimits Rollercoaster Simulation Plugin 2.0.1.17
SimTools game plugin for NoLimits Rollercoaster Simulation
  1. value1
    15,074Coins
    Hi @SilentChill
    I've had a conversation with Ole some time ago about the coming API for V2.2 and for sure we will try to extract the motion data via this.
    Dunno ATM when V2.2 will be ready though.
    Thanks for sharing :)
  2. AceOfSpies
    AceOfSpies Living the Dream!
    Kilwinning, Scotland
    19,614Coins
    Looking forward to it! This is already one of the best games for non-race users to try VR on.
  3. Giuseppe Romano
    Giuseppe Romano New Member
    362Coins
    2DOF, 3DOF, DC motor, AC motor, Arduino
    I haven't understood why the roll an pitch aren't present in the nolimits plugin. For a realistic simulation on a 3dof I think they are needed. Or not? I think the right configuration should be roll, pitch and heave, someone can explain me better?
  4. value1
    15,074Coins
    Maybe pitch, roll and yaw will be available with the IP-API of NoLimits version 2.2.
  5. Wanegain
    Wanegain Active Member
    Bruxelles
    2,008Coins
    The right configuration should be roll, pitch, yaw, heave, sway and surge :p
  6. Giuseppe Romano
    362Coins
    Of course!!!!:grin:grin
  7. Giuseppe Romano
    362Coins
    So, at the moment there is a limit of the game that doesn't has these parameters in output?
  8. AceOfSpies
    19,614Coins
    @value1 - No Limits 2 has updated to V.2.2.0.0 and the plugin no longer works.
    Mike
  9. value1
    15,074Coins
    This is good news! Thanks!
  10. AceOfSpies
    19,614Coins
    @value1 - I hope I didn't ruin your day!
  11. value1
    15,074Coins
  12. SilentChill
    20,595Coins
    Yes because advanced telemetry is now implemented meaning more motion and hopefully all 6dof and some shaking gonna happen !!!!
  13. value1
    15,074Coins
    value1 updated NoLimits Rollercoaster Simulation Plugin with a new update entry:
    Update for NoLimits V2.2
    This plugin makes use of the new API provided by NoLimits.
    A big "Thank you" to Ole Lange for taking the time and effort to implement a genuine API!
    This version of the plugin works with NLS V2.2 and higher! If you run an earlier version of the simulation, use plugin version 2.1.5.0!
    In order to activate the telemetry in the simulation, you must start NLS with the option --telemetry. Note: There must be two "-" in front of the "telemetry"!
    Non-Steam version:
    Create a shortcut to nolimits2app.exe – right click on Properties and add to the the Target --telemetry Note: There must be two "-" in front of the "telemetry"!
    Steam version:
    In your steam client library right-click on the NoLimits 2 Roller Coaster Simulation, select Properties and click on Start Options and add --telemetry
    • Winner Winner x 8
  14. SilentChill
    20,595Coins
    Do we get vibrations now @value1 ? Cant wait to test it as soon as I get chance :D
    And woohoo you wont have to keep updating the plugin now !!!!!
    Thanks for all the hard work you put in again dude awesome work !!
    • Agree Agree x 3
  15. Wanegain
    Bruxelles
    2,008Coins
    Is there more than 3 effects now? Including roll and pitch?
    Very good news indeed and thanks a lot @value1! :thumbs
  16. SilentChill
    20,595Coins
    Hi @value1 ,
    I've tested the new plugin and I have some issues. When we now do a cork screw or similar the sim jumps back from one side to the other when you reach 180 degrees I think. Its like P3D if you do a barrel role and it kicks you right over the other way. I think pitch may be doing the same thing but need to do more testing.
    If I do a fresh capture in sim tools the roll capture 179.4378643 or something like that. Sway doesn't seem to do much at all the rig hardly moves.
  17. AceOfSpies
    19,614Coins
    Hi @value1,
    I've got a problem also with the new plugin. Every time I try to run the game I get an "Unhandled exception error".
    System.Net.Sockets.SocketException (0x80004005): No connection could be made because the target machine actively refused it 127.0.0.1:15151
    at System.Net.Sockets.TcpClient.Connect(String hostname, Int32 port)
    at NoLimitsSimulator_Plugin.Plugin.StartupCommands()
    at SimTools_GameManager.Mod_Lib.GameStarted()
    at SimTools_GameManager.frmMain.tmr_IsGameRunning_Tick(Object sender, EventArgs e)
    at System.Windows.Forms.Timer.OnTick(EventArgs e)
    at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
    Game Engine and Game Manager show that they are connected to the game, but there is no data in the Tuning Centre.
    Any ideas?
  18. hooshang
    hooshang Active Member
    275Coins
    the @SilentChill problem exactly is the same as mine when I just used Heading value for Yaw in FSX(turning point at 180 degree)
    on my mini 6dof rig.but this time for NL2 is more critical...;)
  19. value1
    15,074Coins
    Improved error trapping
    Read the rest of this update entry...
    I think this will fix your issue, @AceOfSpies
  20. SilentChill
    20,595Coins
    Thanks @value1 will give it a go tomorrow :)
