ARDUINO 2 DOF 24V DC MOTOR
Discussion in 'DIY Motion Simulator Projects' started by Dundarx, Jul 26, 2015.
  1. Dundarx
    Dundarx Member Gold Contributor
    - 183Coins
    2DOF, 3DOF, DC motor, Arduino, 4DOF, 6DOF
    Arkadaşlar bir projeye daha önce başlamıştım, iki arkadaş çalışıyorduk, şimdi yalnız devam ediyorum, elektronik bilgim zayıf desteğinize ihtiyacım var.daha önceki çalışmalarımdan fotoğraflar paylaşacağım, herkese kolay gelsin :)
    My english is not good, l'll write by translation, respect s
    152,541Coins
    +11,086 / 56 / -2
    Google translate -
    Friends of a project I started earlier, we are working with two friends, now I continue alone, electronic information I need your weak support var.dah I will share the previous work of my photos, come easy to everyone:) My English is not good, I'll write by translation, respect p ...
    Are you using a Sabertooth?
  3. Dundarx
    - 183Coins
    no I do not use.I will continue working on this :)
  4. Dundarx
    - 183Coins
    LFS and RACE07 I will use the games, simtools gamemanager I have trouble running the game s
    152,541Coins
    +11,086 / 56 / -2
    So you have an Arduino Uno, what is the other board and what code are you using to interface them with SimTools?
  6. Dundarx
    - 183Coins
    Pololu Dual VNH5019 Motor Driver Shild I am using
  7. Dundarx
    - 183Coins
    Hi friends, moved the seat, I will use the LFS, but I have a coding error, unstable movements, help :)
    20150728_112932_resized.jpg 20150728_112940_resized.jpg 20150728_112953_resized.jpg
    152,541Coins
    +11,086 / 56 / -2
    What code are you using?
  9. Dundarx
    - 183Coins
    I ran directly, I do not know how to code to do.
    152,541Coins
    +11,086 / 56 / -2
    You mentioned a coding error, what was that error?
    What code is the Arduino running?
  11. Dundarx
    - 183Coins
    When he opened the game, gamemaneg also see Running
  12. Dundarx
    - 183Coins
    LFS game axis setings help?
  13. noorbeast
    152,541Coins
    +11,086 / 56 / -2
  14. Dundarx
    - 183Coins
    hi friends, I guess I am having trouble in setting interface, you do not get the full results, you look at the settings on the timeview?
    152,541Coins
    +11,086 / 56 / -2
    I am not sure I understand what you mean, I think Google Translate lost something. Can you please post a picture of your setting with arrows to what you mean.
  16. Dundarx
    - 183Coins
    Ok
  17. Dundarx
    - 183Coins
    I tried to do ...
  18. Dundarx
    - 183Coins
  19. bruce stephen
    general contractor
    michigan
    9,115Coins
    you dont need the interface tools area to be populated to use simtools. Are you doing flight or racing? pitch and roll are good for flight but if you are using it for racing start with surge and sway.
    as @noorbeast has suggested read here
    http://www.xsimulator.net/community/faq/simtools-settings-tips-and-tricks.18/category
    in photo with interface settings should be value of 10 for output bit range
    and on interface output the code is wrong it reads
    <axis1><axis2>e
    and should read
    [A<Axis1>][B<Axis2>][C<Axis3>]
  20. Dundarx
    - 183Coins
    Thank You :)
    In the above picture, the area I marked gonna stay empty?
