Large footprint 6DOF motion base ......
Discussion in 'DIY Motion Simulator Projects' started by jthiani, Jun 16, 2015.
  1. SeatTime
    Good to see it is still progressing:thumbs, its still going to be a beast :). I'm very space limited, so the footprint for mine is just over a 5ft diameter circle - basically half yours. For similar reasons I will be using a semi basket design, as being smaller I have to leave room to ensure the capsule does not foul the actuator arms when in motion (edit: looking at the photos, I don't think you will have this issue). SketchUp is your friend for all of this.
  2. jthiani
    jthiani Member
    Knightdale, NC
    588Coins
    DC motor, AC motor, Motion platform, 6DOF
  3. jthiani
    jthiani Member
    Knightdale, NC
    588Coins
    Ok i did the extensions so that when the basket is at the top of the stroke, the arms and the distance between the centers forms an equilateral triangle. My thinking is that this gives me maximum range of motion without putting too much stress on the worm gear mounts.
  4. Atlas974
    Atlas974 old school
    Physics chemestry
    Reunion island
    358Coins
    Great, keep the pics and videos coming ^^
  5. hooshang
    hooshang Active Member
    275Coins
    great design mate,with lower cog you improve the feeling of motions, congrats
    IMO the crank arms are too long for the mototrs and gearbox .i think you should pick bigger hammer or
    use shorter cranck and also stronger steel and materials can help much
    waiting to see it in action
    regards
    Hooshang
  6. BLP
    BLP New Member
    Wisconsin
    91Coins
    Looks great - what type of motors are you using - I am currently working on my project - I just started - I have a Cessna 421 cockpit that I cut off of the fuselage - Trying to figure out what type of frame to build for the base - along with motors and if I should go with hydraulics of electrical - my first project so hope this forum will get me on the right track - again your project looks great -
    BLP
  7. jthiani
    jthiani Member
    Knightdale, NC
    588Coins
    I hear you but after doing the manual test, i like the length of the crank arms. After i do more tests with the full motion cues i will make a final decision on whether to modify them or not
  8. jthiani
    jthiani Member
    Knightdale, NC
    588Coins
    Thanks for the compliments. I am using 2 hp A/C motors. the worm gears have a 15 rpm output with a 60:1 ratio i believe.
  9. BLP
    BLP New Member
    Wisconsin
    91Coins
    How is your project going - been quite busy so haven't had tine to work on mine until today - finally got all the excess metal cut off of the cockpit now it measures 6 feet by 8 feet so am looking at the design of the mounting plate and get it fabricated - got to get it indoors as winter is approaching and I would like to work on it more. Quite new at using this website so hope you don't mind if I converse with you on your project and would like to get ideas on designing mine. do you have more videos posted on this website will try to look for them
    BLP
  10. ho123
    ho123 New Member
    belgium
    198Coins
    Arduino, 6DOF
    nice work would you like to share your dimensions?
  11. eightbit
    eightbit Active Member Gold Contributor
    Fish Farmer
    Trentham Cliffs
    183Coins
    3DOF, DC motor, AC motor, Arduino, 4DOF
    Absolutely perfect!!! Winning! Nuff sed!
