Showroom 3070W 6DOF Seat Mover (WIP Surge_Sway table)
Discussion in 'DIY Motion Simulator Projects' started by Pit, Mar 5, 2014.
  1. Pit
    30,490Coins
    EDIT 65 /EDIT swiss bucks apiece. Not too expensive but the whole table will cost between 800 $ and 1000$ at least. The rails and pulleys are very expensive, I wanted to get a really solid solution because the forces are too heavy for doing things by halves.
  2. RacingMat
    21,050Coins
    @Pit : it looks good this shopping list! :popcorn
    how will you mate the pulleys and motor's shaft?
  3. Pit
    30,490Coins
    Hi Mat, the concept is yet in my brain only, but I have my ideas how to implement all parts together.
    Imaging two independent tables, each have 4 pulleys rolling on rails like on the photo below:
    The 20t gear
    will be welded onto the drive shaft of the motor. The gear is rolling on the rack respectively driving the rack
    which is 1m long. That means, my concept allows to have 50cm for sway (left and right movement), and probably 60cm for surge acceleration and 40% braking (if this is practical), due to the washout function the table should move backwards to the start position after an acceleration (f.eg. while shifting the gear)
    The details follow later because I have to size the room and then I have to sketch the detailed concept.
    The biggest problem is now to bring the displays and the projectors on the surge table and most important for me the projectors have not not to wobble at all. This results in a big effort and a very massy platform. Due to the weight constrains I have to use the slide door pulleys and rails which can resist of that without to be too noisy.
  4. RacingMat
    21,050Coins
    My point was about the mating of these two pieces:
    About your tables, the trick is to insure that both tables keep parallel! I'm sure you will figure out a good solution
    How many motors will you use 1 or 4?
  5. Pit
    30,490Coins
    4, 2 motors for one DOF.
  6. RacingMat
    21,050Coins
    You have 4 pulleys for your surge table : so how many motors will you use to move the 4 pulleys?
  7. Pit
    30,490Coins
    Probably it is not clear what I mean, the 4 pulleys are sticked to the surge table. The table will be driven by the motors using the gears and gear rack which is sticked to the table, of course. Do you understand what I try to explain?
  8. speedy
    speedy Well-Known Member
    Alexandria , Egypt
    7,943Coins
    Good Idea ... just put the motors in the fixed base-table 1 and the rack on the upper moving table 2 with rubber rollers .
    But, How about the torque calculation ? ...
    Pushing the moving table back and forth will need a very powerful mechanism ...
    A small gear attached to the motor output shaft will provide you with the enough force but with a slow linear speed .
    What are the motors rated output torque ?
    What are the 20t gears diameter ?
  9. Pit
    30,490Coins
    @speedy thank you for sharing your thoughts. When I was building the traction loss I thought I need a very strong motor to move the rig to each side. I was wrong. The 300W motor is way too strong, I had to reduce the needed power within SMC3 not to damage the rig. A rolling rig needs much less power than you have to lift it. About this experience I decided to build one table for surge by using two motors each 130W, at least 260W, in minimum 80 cycles per minute and the diameter of the 20t is so I remember EDIT 8.8cm (27cm circumference). Ergo I get a sped of 36cm per second (80 cpm * 27 / 60).
    My rail is only 100cm long - forwards and backwards! That means, for surge forward I can use only 50cm.
    PS: the existing surge effect form the 2DOF seat mover has not to be forgotten! While the table moves forward, the seat does it as well.
  10. townnet
    townnet New Member
    Singapore
    400Coins
    That is gorgeous, nice works man!;)
  11. Pit
    30,490Coins
    one gear rack and one 20t gear 2KG together :eek: :D
    The place where they are is only for viewing purposes.
    • Like Like x 7
  12. speedy
    Alexandria , Egypt
    7,943Coins
    Wow ... That is huge gear :) .
    In order to save weight ... How you're going to split your sim into the new layers/trays ?
  13. speedy
    Alexandria , Egypt
    7,943Coins
    If the small gear is big enough . So I guess he might use the grinder to shape the small gear to fit inside the big one with the male key-way .
    Then making a center hole to it and thread it to accept a fastening screw .
  14. Pit
    30,490Coins
    Dunno know yet...but there are many ideas :)
    I have built already a template how I will connect them together, I will upload a photo later
  15. Pit
    30,490Coins
    @speedy I did a great mistake in my posting above, I mixed up diameter with circumference...the speed is NOT 12cm per second
    80 cycles per minute, the diameter of the 20t is 8.8cm (27cm circumference). Ergo I get a sped of 36cm per second (80 cpm * 27 / 60).
    All the time I was sure there is something wrong, but I could not fiddle it out. I knew 12cm is way too low for what I calculated weeks ago, now I know why. 36cm is a big jump, hopefully the motors will do the work
  16. speedy
    Alexandria , Egypt
    7,943Coins
    Very Good @Pit Very Good ...
    Congrats. you have broken the required speed barrier :grin .
    I just need to know the output axial torque of that 300W motor ? If available please .
  17. Pit
    30,490Coins
    Not 300W, max. 160W each motor, my configuration allows 2 x 130W (each 24V =7A ≙ 12V= 14A = summa summarum 14A / 24V)
    PS to radial load
  18. Pit
    30,490Coins
    BTW @speedy what can we expect from you the next months? After your fire disaster I hope you will build something else? :)
  19. speedy
    Alexandria , Egypt
    7,943Coins
    Stop Reading my mind :p ... I like flying below radar :grin.
    Wooden Planetary Gear with Belts ...
  20. Pit
    30,490Coins
    the beginning, all parts are now available.
    The back of the rig for now on a vertical position:
