Assetto corsa GameDash problem
Discussion in 'Official Companion Apps' started by tadythefish, Aug 9, 2015.
  1. tadythefish
    tadythefish Active Member
    Process automation engineer
    Slovenia
    679Coins
    Hello everyone!
    i'm trying to make my dash work with Assetto Corsa and i hit a bump with Gamedash.
    I can't get the speed working.
    The game sends me values of speed but i cant ROUND them.
    123.5432km/h for example. i can't convert it to 123km/h
    if i use a combination of different functions a can get 123km/h but when the speed drops below 100 the output isn't good. 99km/h i get 990km/h
    im thinking it something with the decimal value that doesn't get converted right.
    any issues with comma math?
    thank you
  2. tombo
    tombo Active Member
    2,444Coins
    DC motor, Arduino
    Maybe the same problem I had.
    Check thios screen i got from value 1 and set in the right screen "Dezimaltrennzeichen" to a "." not a ",".
  3. tadythefish
    Slovenia
    679Coins
    Where is thios screen? Sorry i didn't understand your reply:)
  4. tadythefish
    Slovenia
    679Coins
    the image link doesn't work :(
    i think GameDash doesn't see the data as decimal value but as thousants.
    example: game sends 121.4532km/h
    and if i use ROUND 0 i get 1214532
    i even tried first to ROUND then MATH / 10000 an then ROUND 0 again. i stil got the same result (121.4532). I know it's stupid but if there was any problems with decimal places this coul fix it.
    So no luck so far. Maybe if the author could implement a new function let's say REMOVE 4 ( rour numbers form right to left) for example. then it could work ;)
  5. tombo
    tombo Active Member
    2,444Coins
    DC motor, Arduino
    sorry my answere wasn't helpfull, but i was in hurry.
    I even don't know if this is the solution for your Problem but it helped me with some Gamedash value Problems.
    I try to descripe it better this time:
    First you go to:
    Start-->Control Panel-->Clock, Language and Regions
    Now you go to Change the Date,Time or Number Format-->Additional Settings--> Set Decimal symbol to a dot "." like in the Picture below.
  6. tadythefish
    Slovenia
    679Coins
    Hmmm interesting:) i will be able to try this option today in the evening and i will get back with an answer:) But anyway thank you a million times for your help!!
  7. tadythefish
    Slovenia
    679Coins
    My friend you are the best! That was exactly the problem!! Now everything works like a charm! O owe you a couple of beers!!! Thank you sooo much:)
    • Like Like x 5
  8. tombo
    tombo Active Member
    2,444Coins
    DC motor, Arduino
    Nice you got it working :)
    all thanks go to @value1 which showed me this way as I had the problems. :thumbs
  9. tadythefish
    Slovenia
    679Coins
    Thank you both! :)
