Blast from the past. F1 2012.
Discussion in 'Off Topic - All other stuff here' started by Archie, Mar 12, 2015.
  1. Archie
    Archie Eternal tinkerer
    Wollongong, NSW, AU
    3,797Coins
    Ok, so I downloaded F1 2012 from steam and setup my profile for the sim.
    I have to say, this game is absolutely a different beast when using a motion simulator.
    Tightly strapped into my seat, flying around Monaco is simply amazing.
    Being F1 I don't need massive movements, but I have PITCH up a lot higher than all the other axis and the feeling you get on that track is astonishing!
    If you don't have F1 2012, I can recommend you re-visit this little gem!!
    (Thanks so much for providing an excellent plugin as well - @yobuddy / @value1)
  2. Archie
    Wollongong, NSW, AU
    3,797Coins
    PS - Don't buy from Steam. It's only $8 on "thebluedroid"
  3. Vef445
    Vef445 Active Member
    Denmark
    597Coins
    Hi @Archie ,
    Does the plugin for F1 2012 still work for you? I've just downloaded it from Steam but I don't get any data passing through. :/
  4. Archie
    Wollongong, NSW, AU
    3,797Coins
    Not played it for a while @Vef445 - I will fire it up tonight and see if it is still working for me and let you know....
  5. Archie
    Wollongong, NSW, AU
    3,797Coins
    Hey @Vef445 - Checked tonight and F1 2012 still works fine for me.
    Check your versions match below:
    Game version: (F1_2012.exe)
    Plugin Version:
    Confirmed it is the latest one - 3.0.0.3
    If still no joy, post back and will try and assist where I can.
  6. Vef445
    Denmark
    597Coins
    Thank you very much for the feedback @Archie :) I'm out traveling this week, I'll look at this on Friday and let you know ;)
  7. Vef445
    Denmark
    597Coins
    All right, fixed :) I had to point the folder to mydocuments/mygames/ for patching, instead of the Steam folder (even though I'm running Windows 7 32bits).
    Lovely!!! :) :)
