Handbrake Homemade
Discussion in 'DIY peripherals' started by -kevin-, May 17, 2015.
  1. -kevin-
    -kevin- Fast e Furious
    Termo Tecnico industriale
    128Coins
    Handbrake Homemade
    Because I like so much the rally, I built this handbrake which for the moment is digital .. then I will upgrade to convert it to analog
    needed:
    2 plates of 15x10 cm
    1 microswitch that soon will be replaced by a linear potentiometer and USB interface will use a game pad
    1 threaded rod from various bolts m8 +
    2 springs 6 cm for a diameter of 1 cm
    3 extensions for threaded rods M8 8cm
    an aluminum tube from diamotro 2 cm coated with carbon film
    a recovery lever 30 cm, that goes inserted in the aluminum tube
    Some photos is a video in detail of the building:
    For the moment I connected the wires of the microswitch to the board of the exchange g27
    Video
    • Like Like x 7
    152,535Coins
    +11,085 / 56 / -2
    Thanks for adding the pictures and video @-kevin-, great job :thumbs
  3. -kevin-
    128Coins
    It is a pleasure for me @noorbeast, contribute to this community that has given me so much :thumbs
  4. Pedro Melim
    Pedro Melim Smoother Racer
    Programmer
    Funchal
    710Coins
    @-kevin- looking into making some home made handbrake for myself...can i know how much did you spent in all of those parts?i have an idea on how to make one but i will "steal" yours if i see its worth it hehe
  5. -kevin-
    128Coins
    Steal all you want @Pedro :)
    Something it had it already .. however, it cost me about 40 € all inclusive ;)
  6. Cluclu
    Cluclu Member
    443Coins
    :thumbs You have a link to the springs ?
  7. -kevin-
    128Coins
    Sorry if I reply late ... but I've been pretty busy
    The connections I made them on the board of the exchange for the G27 here are the photos: ;)
  8. bberger
    bberger Member
    306Coins
    I'd like to know that too.
  9. stamer57
    stamer57 Member
    963Coins
    Great Job
  10. alxdr
    alxdr New Member
    IT
    - 39Coins
    Nicely done, it gives me ideas... :)
  11. -kevin-
    128Coins
    Thank you guys ;)
    @bberger on the handbrake and connected a simple microswitch.
    I do not know if you mean this
