Showroom my 6dof (reproduction of ckas)
Discussion in 'DIY Motion Simulator Projects' started by vulbas, Mar 27, 2014.
  1. vulbas
    vulbas Active Member
    france
    1,103Coins
    AC motor, 6DOF
    hello,
    it was time that I did not come.
    I redid the top part of the square tube. 40x40x2mm.
    the other was not stiff enough.
    Old is over, the new below
    I also redo the rods. and spacers
  2. 741852cp
    741852cp Member
    china
    106Coins
    2DOF, AC motor
    A better efficiency 90 °
  3. 741852cp
    741852cp Member
    china
    106Coins
    2DOF, AC motor
    The circumferential converted to linear motion
  4. jthiani
    jthiani Member
    Knightdale, NC
    588Coins
    DC motor, AC motor, Motion platform, 6DOF
    Very impressive sim. so did you end up using simtools with the thanos board??
  5. vulbas
    france
    1,103Coins
    AC motor, 6DOF
    Hello.
    thank you.
    yes I use simtool with the card of thanos :)
  6. vulbas
    france
    1,103Coins
    AC motor, 6DOF
  7. cthiggin
    cthiggin Active Member
    Self-Employed
    Montgomery AL USA
    15,210Coins
    Glad to seen your continuation! Looks good.
  8. bruce stephen
    general contractor
    michigan
    9,115Coins
    i like it so far. can't wait to see it move.
  9. vulbas
    france
    1,103Coins
    AC motor, 6DOF
    hehe, it has already moved. I removed the screen, I expect the oculus :thumbs
    • Winner Winner x 3
  10. momoclic
    momoclic Active Member
    Retraité
    Nantes - France
    2,773Coins
    DC motor, Arduino
    ça pleut le boulot ici...
    Pense à l'arrêt d'urgence à ce coup-ci ! ;)
  11. vulbas
    france
    1,103Coins
    AC motor, 6DOF
    ho que oui :grin
  12. vulbas
    france
    1,103Coins
    AC motor, 6DOF
    new video
  13. momoclic
    Retraité
    Nantes - France
    2,773Coins
    DC motor, Arduino
    ça bouge bien toujours, peut-être un peut trop en vertical ?
    it still moves well, maybe a little too vertical?
  14. bruce stephen
    general contractor
    michigan
    9,115Coins
    surge seems backwards? it looks as though the platform goes backwards on braking and forward when you press the gas pedal?
    sweet build!
  15. vulbas
    france
    1,103Coins
    AC motor, 6DOF
    bruce, the settings are okay
    i want reproduce G in a turn.
    how, when turns on a race track, the simulator roll at left or right with my 6dof ?
    on this video, when the car turn, the simulator roll. i want reproduce this with my 6dof.
    is it possible ?
  16. noorbeast
    153,770Coins
    +11,149 / 57 / -2
    Nice job.
    I agree with @bruce stephen surge is reversed to what it should be.
    It is sway you need to adjust for the corners, your sim is certainly capable of it.
  17. BlazinH
    16,689Coins
    Whether surge is backwards or not is just preference really. Surge and sway tables need a very large range of movement in order to work properly if you ask me. But with limited movement, most run their tables opposite of what is normal, just the way seat movers work. But that is what is technically speaking backwards or reversed imho! When was the last time you pressed on your cars accelerator and went backwards when you weren’t in reverse gear?
    Check this video out starting @1:06 or 3:10 where the motion starts. Its not a racing simulator however, just a driving simulator.
  18. vulbas
    france
    1,103Coins
    AC motor, 6DOF
    When you brake, your body goes forward. this is what it takes to reproduce.
    it must reproduce the effects felt, not the car's movements ;)
  19. bruce stephen
    general contractor
    michigan
    9,115Coins
    Right we use gravity not the sim to reproduce sway and surge. If possible have someone else drive a car with you in the passenger seat. Close your eyes while they apply the brakes. What you feel is forward inertia sustained by prolonged application of force. You would need a large building to produce that without using gravity. Therefore leaning you forward produces the most accurate braking effect with a simulator that doesn't actually move on a y,x table. And leaning you back to reproduce acceleration. Just like when you enter the turn it should lean the opposite direction of wheel input to reproduce g force in turn using gravity. When you are nearing apex of a turn you should feel the sim "laying down" on the front outside tire. On a left turn oval you should feel it working and leaning on the right front in braking and the right rear upon acceleration. These are prolonged sustained effects not just felt for a microsecond.
  20. bruce stephen
    general contractor
    michigan
    9,115Coins
    And ps I still think your sim is badass!
