Just rescued 6 of these out of a skip at work.
Discussion in 'Motor actuators and drivers' started by SilentChill, Aug 14, 2015.
  1. SilentChill
    20,601Coins
    Have no idea what I will do with them but sure I can think of something.
    A lot of the top bearings were seized and rusty but the gearboxes seem perfectly good. Commutator were covered with crap but clean up nicely. 20150814_143624.jpg 20150814_143618.jpg 20150814_143639.jpg
    Should all work like a charm once I fix them up a little.
    153,890Coins
    +11,154 / 57 / -2
    With freebies like those I am surprised friends have not hit you up to build them sims after the success of you traction loss and 6DOF rigs!
  3. SilentChill
    20,601Coins
    All my friends are console gamers not one has a half decent PC to play on. Maybe I will make dual 6DOF's :D
  4. wannabeaflyer2
    london uk
    8,350Coins
    Mate There is Gold where you Dumpster dive LOL, i shold be that lucky . One Mans Junk is Simbuillders Treasure Trove . Cos even if it's broke we will fix it .. Nice Find Sir
    • Agree Agree x 3
  5. BlazinH
    16,691Coins
    Hard to beat a freebee! :p To bad they don't have more power though.
  6. SeatTime
    A decent motor/gearbox is the most expensive cost for a 6DOF, so good find :thumbs. The thing with commercial motors is that their ratings are often continuous, therefore with a bit of cooling, you can normally overdrive them by quite a bit.
  7. SeatTime
    Eg/ Standard rated motor against a commercial rated motor - the smaller motor is rated at 12v 350W and the bigger one is 12v 320w (continuous). Many 'standard' motors are only good for 15minutes at their full rated load - cycle them at more than that and you will want some cooling, which some members have implemented.
