Showroom 3070W 6DOF Seat Mover (WIP Surge_Sway table)
Discussion in 'DIY Motion Simulator Projects' started by Pit, Mar 5, 2014.
  1. noorbeast
    152,640Coins
    +11,087 / 56 / -2
    Nothing like ripping your sim apart, sorting through and modify its carcass and then end up with something even better once it is rebuilt!
    I am looking forward to following your surge upgrade @Pit.
  2. Pit
    30,498Coins
    Very early stage - really alpha but already I'll show you an impression how it will work (hopefully - lol)
    • Like Like x 5
    • Winner Winner x 4
  3. value1
    15,080Coins
    OMG! This will be awesom!!! And as usual in the very high and appealing quality of Pit-built!
  4. speedy
    speedy Well-Known Member
    Alexandria , Egypt
    7,944Coins
    Wooooooooooow ... LLLLLLLLLLove it .
    Idea :nerd ... please put a scale under your feet plus a similar total weight to measure how much force do you need from the pinion to push/stop/reverse this beauty .
    Actually ... I couldn't calculate it from the given previous motor specification
    " radial torque ???? "
  5. Pit
    30,498Coins
    @speedy thank you very much.
    Concerning the radial torque I don't have any other information as already given.
    Regarding the weight or force to push the sway table I can do it with one finger... :) I would compare it with a shopping cart. Furthermore there is "no" noticeable rolling resistance. NTL I am afraid that the motors will be the limited factor despite of the power of 260W / layer. Anyway I like trial and error...
    PS: the specs say 130W continuous but 6.9A max = 165.6W (24V) x 2 = 331.2W peak / layer. IMO should be enough.
  6. speedy
    Alexandria , Egypt
    7,944Coins
    please test and try and consider the fast side to side movements will require more than one finger :) .
  7. Pit
    30,498Coins
    hehe - of course not if the rest of the rig stands on the table . The one finger test was only an example how much force is needed to push the empty tables.
  8. Pit
    30,498Coins
    A newer model - IMHO I should achieve the estimated speed without big issues. The professional rig seems to be not as fast as I imagined.
  9. value1
    15,080Coins
    P = ΔE/Δt = ½mv²/t
    with m = 150 kg
    v = 1 m/s
    t = 1 s
    P = 75 W
    add the friction and the efficiency factor and 150 W should be enough.
    • Informative Informative x 3
  10. Pit
    30,498Coins
    Wow, @value1 your are a great guy, I am highly pleased:cheers 1m/s is really fast, the table has a max. speed of ~36cm/s. It is very important, how the weighty mass will be accelerated - if it would be too sluggish all effort would not be worth the investment of time and money.
  11. SeatTime
    Mine used a single 200W motor - it moved quick enough - there was also a bit of weight in it at the end with a heave module built into the seat (although I don't think it was ever as heavy as yours). Notice how it is moving forward for braking, as this felt the best with no working washout.
  12. Pit
    30,498Coins
    Nice build! ay @yobuddy promised, we will fiddle out the washout filter. How far is the surge table moving? 50cm (20 inches)?
  13. RacingMat
    21,060Coins
    I understand what you're saying but just a clarification
    It's not really about speed... but acceleration.
    - Uniform speed (m/s) won't give you any feelings
    - You have to aim good acceleration (m/s²) because this will give you the gForces​
    I stay tuned to your post and progress :)
  14. Pit
    30,498Coins
  15. speedy
    Alexandria , Egypt
    7,944Coins
    You have the touch of a SURGEON @value1 ... :thumbs
    So ...
    P = ΔE/Δt = ½mv²/t
    where :
    m = kg
    v = m/s
    t = s
    P = W
    https://www.physicsforums.com/threads/power-problem-pushing-a-train.373588/
    perfect :thumbs
    • Agree Agree x 3
  16. RufusDufus
    RufusDufus Well-Known Member
    Adelaide Australia
    16,317Coins
    Really nice build @Pit, can't wait to see it in action!
  17. Pit
    30,498Coins
    Thank you mate :)
    Progress today: after 1 million not working ideas and tinkering I think I got it - the way how the motors will drive the sway table (one motor at the front and one at the back):
  18. SeatTime
    A think a bit over 300mm travel, but I'm not home at the moment to be sure (in Japan :)).
  19. Pit
    30,498Coins
    Electronic parts are up and running, all successfully tested. The Pololu VNH5019 are high quality samples, the chips are totally flush to each other, nothing to compare to all MMs I ever had.
    • Like Like x 7
  20. Pit
    30,498Coins
    The first layer is "ready", only the PSUs have to be reconnected on the layer and the second motor, too (to be functional), so be patient this evening I will present you the first moves :p -
