no capture yoda
Discussion in 'Yoda - ForceFeedback Scanner' started by pitulo, Jun 15, 2008.
  1. pitulo
    pitulo New Member
    0Coins
    Hello
    Can not capture with yoda scanner the effects of GT LEGENDS. Uses XP And LOGITECH G25.
    Only can capture the effects of R-factor and I get an effect only =SineDirectX8 / 9 (only acceleration)
    What can I do to reap the full effects of yoda?
  2. el_txus
    el_txus Member
    Las Palmas de Gran Canaria - España
    421Coins
    Hello
    how to use plugins already made as of rFactor. I do not understand the modus operandi Does anyone can explain it to me? or at least give me a hint
    Regards
    Hola
    cómo se usan los plugins que ya están hechos como el del Rfactor. No entiendo el modo de funcionamiento ¿Alguien me lo puede explicar? o almenos darme una pista.
    Saludos
  3. el_txus
    el_txus Member
    421Coins
    Hi Sirnoname
    ok, selct Rfactor plugin
    conection with force profiler OK!
    I'm looking at, but nothing happens, may be that my version of rFactor not work with the plug my version is 1,250. if that's, why there plugin for the 1,250 or I have to install 1,150
    regards
  4. egoexpress
    egoexpress Active Member
    Germany - Frankfurt/M
    422Coins
    There is a key in r-factor, which enables/disables simultator output. But I cannot remeber which it is by default, as I changed them all. I think it was one of the ASDF keys. Try all alphabetic keys on your keyboard during race, or look into the key-konfig menu...
    Regards
    Christian
  5. el_txus
    el_txus Member
    421Coins
    Ok I will try
  6. egoexpress
    422Coins
    just in case it is not clear. The Force-Sender sends the data directly to the Force-Profiler. You dont need Yoda at all.
  7. el_txus
    el_txus Member
    421Coins
    Hi Again
    I pressed all the keys and the only one that seems like you say is, hardware plugins enable / disabled is it this one?.
    I have also seen that when using the force-sender with the plugin, when I press sen, the monitor of the actuators of force-profiler gets paused. ¿You know what is happening? I managed to send the effect No1 by yoda and is ok, but nothing happens with the plugin (No yoda when i use de plugin). With the Racer pluging the same happens to me.I'm running the game and the force-sender on a computer with Windows Vista OS. Could this be the problem?
    Regards
  8. el_txus
    el_txus Member
    421Coins
    I have it copied in the directory rFactor / plugin since the beginning.
  9. el_txus
    el_txus Member
    421Coins
    These are the steps i have followed
    1º copy the plugin in the Rfactor/plugins
    2º start force-sender / select the Rfactor plugin / press send
    3º press start on the force profiler
    it does not matter in the effects from 21 to 40. Am I doing something wrong?
    [​IMG][​IMG]
  10. egoexpress
    422Coins
    Yes, It is that one. It has to be set on enable!
  11. el_txus
    el_txus Member
    421Coins
    Hi to all
    Sorry I'm very stupid, instead of copying the xsimplugin.dll in the folder plugin rFactor, had copied Rfactorplugin.dll, a grave mistake thank you very much for the help.
    Try not to repeat these mistakes.
    Regards
