Problems with Project Cars and Xsim
Discussion in 'DIY Motion Simulator Building Q&A / FAQ' started by Sin.Schumi, Aug 17, 2015.
  1. Sin.Schumi
    Sin.Schumi Member Gold Contributor
    - 18Coins
    SCN5
    Hi !!
    at first sorry my English iss not perfect, I am from Germany, and I have sucessfull convert Frex to XSim..
    My first Test Assetto Corsa works fine, but with Project Cars it dosent Work :(
    Here my Worklist:
    1. Loaded the Plugin 1.0.0.0 from here in the Game Manager
    2. Patch the Game
    3. start PCars and set MMF on
    4. Start the Game but nothing work on my Seat
    5. I have Startet it in Window Mode to See the Game Manager (Game Running) but he says Connectet
    Please Help me I am very Disapointet :( :(
  2. Lars
    Lars New Member SimAxe Beta Tester Gold Contributor
    381Coins
  3. zigzag49
    zigzag49 Active Member
    726Coins
    Bonjour
    Nouveau plugin +
    Testez les options du jeu, vous allez à: Options / visuels / matériel Et oui vous mettez dans l'utilisation de la mémoire partagée.
    Hello New plugin + Test the game options, go to: Options / visual / material And yes you put in the use of shared memory.
  4. Sin.Schumi
    - 18Coins
    SCN5
    Ok Thx to Lars for plugin.. my Next Problem iss The Roll, when I am start PCars i feel the track going up and down, but the Roll Effect in Corners iss very Minimal
    Can anyone show me how to Setup ist for a better Roll effect ??
  5. zigzag49
    726Coins
    Sorry with google translate I do not understand the issue:(
    153,758Coins
  7. Sin.Schumi
    - 18Coins
    SCN5
    Thx, but iss anyone here to help me in German Language ?? It would Help me More to understand the Game Engine and Game Manager, I ary Sm very Sad that its dont Workng like the Simcom Base there i had better Response in the Game for the Effects
    But I try to Post it in English....
    When I drive in PCars my Seat dont give me a Feedback of Throttle and Break it only will be Moved minimal...
    In a Corner the same, no Feedback for Right and Left Roll, only minimal... But when I am in the Green the Seat will be Shaking and you have the Effect ..
    Sorry for my English but I try to keep it better ;)
    153,758Coins
    @RaceRay can you or another bi-lingual German speaker please translate how to do a base setting in the Tuning Center and then tweak the values?
  9. tombo
    tombo Active Member
    1,969Coins
    DC motor, Arduino
    If you would like you can contact me in German. I can try to help.
    • Friendly Friendly x 3
  10. Sin.Schumi
    - 18Coins
    SCN5
    Here are my Settings....
  11. Pit
    30,510Coins
    and if @tombo has no solution which I do not expect I would befriend @Sin.Schumi.
    Falls @tombo wider Erwarten nicht weiter kommt kann ich auch helfen. Aber erst am Montag...
    • Friendly Friendly x 2
  12. bsft
    need to see tuning centre numbers please
