New project
Discussion in 'New users start here - FAQ' started by Kass55, Aug 21, 2015.
Arduino or jrk controllers for 3DOF or 4DOF
  1. 2 x Arduino
    66.7%
  2. 3 x JRK
    33.3%
  1. Kass55
    Kass55 Member
    PC support
    315Coins
    I built a 2DOF seat about 20 years ago,
    using a car universal joint and 2 electric window motors.
    The problem then was that software tools didn't exist, so I could integrate into games output.
    My knowledge of electronics is basic, so it didn't work well and in the end I broke it up.
    The "feel" of 2 axis around a central pivot in a 2DOF system is not very realistic, more like arcade. The problem being its a too rigid, no give, in a real saloon car you "feel" tyres & suspension working.
    So I'm planning a new 3DOF or 4DOF project, I want to "feel" acceleration & cornering.
    My best game on PC is: codemasters GRID Autosport
    (although Race Driver 3 is most realistic, the graphics are now too old).
    I have plenty of time and can do frame and software, the problem I will have is the electronics and controllers, so want to pick the easiest option with these to get running.
    Budget is limited to approx. £500 all in, so I'll use second-hand electric motors.
    I have spent many days scanning this website...
    I think I'd like to use 2 x Arduino + 2 x Moto controllers (for 4 electric motors) but some one said jrk controllers where easier to setup ?
    Do either controllers come with wiring / setup instructions ?
    Also I assume 4DOF will "feel" more like a real car ? and be easier to understand setting up ?
    152,117Coins
    +11,066 / 56 / -2
    When you say a 3DOF or 4DOF it would help to actually have a sketch of the actual designs you have in mind.
    There is plenty of information in the FAQs regarding setting up JRKs or Ardunio/MMs, and the FAQs also cover many other aspects of building a simulator:
    http://www.xsimulator.net/community/faq/jrk.8/category
    http://www.xsimulator.net/community/faq/arduino.6/category
    http://www.xsimulator.net/community/faq/motor-driver-for-arduino-compatible-controller.11/category
    http://www.xsimulator.net/community/faq/building-resources.12/category
    Many find a well setup 2DOF to be fairly realistic, though traction loss is a popular addition for racing simulators as you can then feel the rear end breaking loose. I have just added heave to my sim and consider that also makes a huge difference to how you feel the road surface and bumps.
    Before making any hard and fast decisions have a good look through existing member builds, it will likely help you refine your ideas as to what you may like to build: http://www.xsimulator.net/community/forums/diy-motion-simulator-projects.22/
  3. Kass55
    Kass55 Member
    PC support
    315Coins
    Hi, Thank you for the links
    I was hoping for more people to respond to the vote, so that I could gauge with controller was most used / liked, Ardunio/MMs or JRK.
    I'm getting some advice and will draw a daft design out at some point, once I've built a small test rig with a controller / motor working.
    Electronics was the problem previously, so I'm solving this issue first.
    152,117Coins
    +11,066 / 56 / -2
    JRKs are easy to set up and offer precise control, but are more expensive. Arduino/MMs are flexible and good value for money but take a bit more effort to set up and of late there have been quite few faulty MMs from cheaper suppliers: http://www.xsimulator.net/community/faq/reputable-monster-moto-suppliers-testing-before-use.158/
    Spend some time in the FAQ and member build section, there is no such thing as DIY consensus around control boards, PSUs, pots or even motors, rather there is a good deal of diversity in designs and components.
    • Agree Agree x 4
  5. SeatTime
    Hi @Kass55 IMO you need to decide on a design, especially if you do not want to use a centre pivot and then chose suitable motors/controllers/drivers.
  6. Kass55
    Kass55 Member
    PC support
    315Coins
    Thanks, following advice, I have ordered to JRKs for ease of setup.
    I have also decided to build another 2DOF seat first, before going to 3 or 4. Start off at walking pace at lower budget.
    So single pivot to start with, while getting going.
    I attach my design drawing below, Seat movement only.
    I placed motors at the front because I have limited space behind me (small bedroom).
    Tennis balls are to create less direct rubber like feel, similar to tyre feel.
    Bass speaker is to create engine vibrations in the seat, may replace with kicker depending on how well it works.
    Tip: I use 2 fans attached via USB to blow air over hands & lower face. I think this works well, giving more feel of speed/moving.
    152,117Coins
    +11,066 / 56 / -2
    Not sure how the tennis ball idea will go given the forces our sims generate, but there is nothing wrong with experimenting.
    In a compact design you need to maximise the leverage by having the motor as far forward as it can be and the connecting rod mounting to the seat frame at least swab height or higher, so it is above the center of gravity, see the red line in the picture.
    You also need to ensure the seat is balanced properly: http://www.xsimulator.net/community/faq/find-the-center-of-gravity-to-balance-a-motion-simulator.55/
  8. SeatTime
    Please take a video when you carry out tests with a test pilot on it :). IMO I think tennis balls would allow the chair to oscillate under a riders load and likely fail over time :eek:. Maybe better to try suitably rated shock mounts:think.
  9. bsft
    @Kass55 , I ve done what you are looking to do
    http://www.xsimulator.net/community/threads/desk-racer-2dof.5326/
    May I suggest forget the tennis balls, once you get a good profile, you feel like you are in a car racing.
    The tennis balls could absorb some of the finer vibrations, you said this "Tennis balls are to create less direct rubber like feel, similar to tire feel."
    My question to you would be, have you actually been in a proper competition vehicle? Because Ive spent time behind the wheel and as a passenger and they usually are as hard as hell in suspension, You cannot feel any tire suspension.
  10. Kass55
    Kass55 Member
    PC support
    315Coins
    Thanks Noorbeast, I'll mount motors & rods as suggested.
    I have driven real race cars, the suspension needs to be firm & controlled but still needs to move / give a bit.
    I think bump stops or old BL mini damping cones are too heavy duty for my weight.
    Shocks and springs to expensive and too little room.
    I was thinking tennis balls or similar because they are cheap and I double / triple up as needed.
    I'm simulating a car rather then a train on rails. I will feedback / video once I get it going.
    I want a little give, without flopping about, to dampen bumps a bit but not completely.
    I planning engine vibrations will come from the bass speaker directly mounted to the seat, but haven't tested this either yet.
  11. bsft
    I just thought of something @Kass55 , generally in game, the motion and action of the car is reflected in the motion of the seat. I was playing AC last night and driving an old Audi , and it was a boat to drive, very sloshy and very little heave motion, then I played a more modern car, and the difference was night and day. Much more response and nastiness in motion.
  12. Nick Moxley
    I also Do not suggest the "tennis ball" idea. All you'll be doing is working the motor's harder than they need to be.
  13. Kass55
    Kass55 Member
    PC support
    315Coins
    Update, I have bought:
    1 race seat, 1 universal joint, 2 wiper motors, 2 Jrk controllers and 2 hall sensors
    Connected motor, Jrk and hall sensor to spare 500w PC power unit (I measured output volts 15v and 6v)
    and installed software to separate PC
    With Feedback set to NONE, motor works well with no errors.
    I measure Vout and hall sensor is working.
    However, with feedback as Analog, I can calibrate feedback with "Learn" fine,
    but motor does NOT run but Jrk reports no errors.
    Anyone had problems / suggestions to get Hall sensor and Jrk working together, as I am stuck ?
    152,117Coins
    +11,066 / 56 / -2
  15. bsft
    Did you find the centre point of the hall effect pot?
    Go to feedback tab, reset to full range, apply settings and watch the graph the right hand corner, turn the pot shaft t find its centre. Then match it with the lever, Then go set feedback
  16. Kass55
    Kass55 Member
    PC support
    315Coins
    Thanks both. The problem is related to PID tab.
    Nothing happens while the top three values are zero.
    So I set same values as noorbeast used and .... the motor shakes arm , very small movement back & forth.
    Plots graph shows feedback swing approx. 100% to 100%
    Errors tab shows max current exceeded (I have limited max current to 10A - which drove motor fine, before feedback was enabled).
    Increasing max current to 12A flips out PSU.
    I'm now going to connect up a separate 5v power for the hall sensor, to test if motor draw is effecting hall sensor,
    and try a spare higher 650w PSU.
    152,117Coins
    +11,066 / 56 / -2
    To assist troubleshooting you really need to verify what you have and have not done.
    Did you follow the steps in setting the Max and Min values in the Feedback tab?
    For now just leave the Max Current at 0 and let the JRK work it out.
    Please post screen shots of the settings for every tab.
  18. Kass55
    Kass55 Member
    PC support
    315Coins
    Good news, new separate power supply fixed issue, motor now moving up and down,
    I just need to fine tune feedback.
    I don't understand PID settings, has anyone used different setting from: 0.39, 0, 0.5
    What does PID settings do anyway ? (effect motor power ?)
    My PSU should shout off at 30A,
    So this setting safe ? Also I have not yet fitted heatsink cooling to Jrk.
  19. bsft
    PID can be a curly one, essentially using P is how fast the motor moves and D is how fast the motor stops, but both play a role in stopping them motor from twitching like a bastard.
    I can end up with different PID and motor settings on each motor.
    But working with motor power settings can help.
    Heres a bit of a guide.
    Guide to setting PID and motor settings on JRKS
    max accell and max duty at 500, max duty while feedback out of range 500
    current calibration 130
    max current 0 (unlimited)
    PID period 20ms
    Integral limit 10000
    With PID, Leave I alone and at 0
    Using the slider bar in INPUT tab of utility only, no simtools, this is how its done.
    Set P, I , D to 0 in the decimals, apply settings, now start with P only and work up in increments of 0.1 , aplly settings, go to INPUT tab, tick the box "automatically set target", click run motor and either slide the bar fast from side to side or use the home/end buttons to do max, min motor throwing.
    Work up in 0.1, so next would be 0.2, then 0.3, etc. Until you find when you move the slider bar, the motor twitches like a bugger. Once you get that, halve that figure you have in P. So if its say 0.7 , you would put in 0.35.
    Now dont worry if when you click apply settings, that the number is not exactly what you typed in.
    Once the P number is halved like I said, go to D and work up in increments of 0.1 like you did with P. Apply settings, go to INPUT tab, and run motor and move the slider back and forth fast until the motor lever stops overshooting its stop point and starts to be very solid in stopping.
    So for example, you may have a final figures of P 0.3672 , and D of 0.8231 for example. Do not use those figures, I am using an example of what may be the final numbers.
    I have found when I do put in say 0.8, apply settings, it gives me 0.79999 or something like that.
    Leave max current at 0 (unlimited) , JRK is protected internally and will not nuke, just shut down.
  20. Kass55
    Kass55 Member
    PC support
    315Coins
    Thanks bfst
    This makes things more clear to me.
