K8055 wiring question
Discussion in 'SimAxe Motion Controller' started by Mxcobra, Sep 5, 2015.
  1. Mxcobra
    Mxcobra Member
    229Coins
    Just getting ready to wire up my board... Question can I directly connect the K8055 velleman to the Rock N Ride valvle body.. It looks like it has built in. Relays on the body..
  2. Mxcobra
    Mxcobra Member
    229Coins
    Could use some help with this today.... Please and thank you :)
  3. SeatTime
    Hi @Mxcobra - The equipment your using is not that common, you will have to be patient and hope a user with the required knowledge is on-line and reads your post - such is life :).
  4. Mxcobra
    Mxcobra Member
    229Coins
    I see that... I have been searching the forum like crazy.. And using my good buddy Google... Coming up empty.. I might just dig in and starting splicing wires and soldering soon... Trial error and a little "just go for it" never hurt anyone...
  5. SeatTime
    Don't know your background, but if you have some basic test equipment you should be able to nut-out what is going on. Good luck :thumbs.
    153,746Coins
