6 DOF Wood Flight Simulator
Discussion in 'DIY Motion Simulator Projects' started by MagicEdge, Sep 16, 2015.
  1. MagicEdge
    MagicEdge Active Member Gold Contributor
    Aircraft Technician
    Justin' TX USA
    1,327Coins
    20150914_185334.jpg 20150914_185345.jpg 20150914_185633.jpg 20150914_185611.jpg 20150914_185500.jpg 20150914_185534.jpg Start of 3 6 DOF Wood Flight simulators. 1 each for my boys and 1 for me using DCS World.
    • Like Like x 8
  2. Mmcool
    Mmcool Member
    USA
    1,174Coins
    Which motors are these? Are they servomotors?
    Mike
  3. Kirk
    Kirk Member
    Sr Software Engineer
    Texas
    15,087Coins
    2DOF, DC motor
    I've admiration for anyone building a Stewart platform rig, and you decide to build *three*... :)
    Truth be told, it probably won't be much more difficult than one, but still... Wow.
    And, lucky kids! Their very own 6DOF simulator. I'm certain quite a few members here wouldn't mind being adopted. :)
    • Funny Funny x 2
  4. Historiker
    9,205Coins
    Subscribed! :)
    153,740Coins
    Me too!
    I can predict with confidence where your power bills are headed in the future once you get all three sims up and running ;)
    • Funny Funny x 2
  6. MagicEdge
    Aircraft Technician
    Justin' TX USA
    1,327Coins
    They are the Bodine 12v dc gear motors discussed here xsimulator.
  7. MagicEdge
    Aircraft Technician
    Justin' TX USA
    1,327Coins
    No disappointment this time. Most all resources and parts aquired.:thumbs
  8. SilentChill
    20,601Coins
    Nice work John :) and wow didnt realise you were going to build 3 !!!! Good luck and cant wait for the updates :)
    • Optimistic Optimistic x 1
  9. Blame73
    Blame73 Well-Known Member
    8,314Coins
    I tried to buy those too, but shipping to Italy would have cost me more than motors themselves - I should have paid delivery costs for each motor!
  10. Blame73
    8,314Coins
    And good luck with your project, of course!
  11. MagicEdge
    Aircraft Technician
    Justin' TX USA
    1,327Coins
    Thanks Craig and for the inspiration. Cheers to you. All the sharing of ideas and knowledge here at xsimulator is breath taking.
    • Agree Agree x 3
  12. bruce stephen
    general contractor
    michigan
    9,115Coins
    oooo same motors im gonna use your my hero. cant wait to see it progress. did you decide on controllers?
  13. MagicEdge
    Aircraft Technician
    Justin' TX USA
    1,327Coins
    Arduino UnoR3 and Monster Moto Simtools and SMC3. Hope this helps.
  14. MagicEdge
    Aircraft Technician
    Justin' TX USA
    1,327Coins
    ;)Here is the latest build before flying out tonight.
  15. Historiker
    9,205Coins
    Looks good! Can I make one suggestion? You might use plywood at the mounting points instead of lumber. Much stronger and less likely to split along the grain. Far less likely to compress as well.
  16. MagicEdge
    Aircraft Technician
    Justin' TX USA
    1,327Coins
    Thanks Historiker, I know as well about quality plywood. The motor mounts are dried southern yellow pine. The 2 x 8's set in my building for 6 weeks before using, dimensional lumber has its strength and durability when chosen carefully. I speak with experience for both. You are knowledge about wood. I appreciate your input.:)
  17. WhiteGoblin
    WhiteGoblin Member
    California
    549Coins
    3 sims... What is your expected cost for them?
  18. MagicEdge
    Aircraft Technician
    Justin' TX USA
    1,327Coins
    ;)8 to 10 thousand USD. This includes computers, controls and flight cockpits with lots of switches and displays. I try not to keep track of funding only look for good buys.
  19. SilentChill
    20,601Coins
    Are you looking to mount monitors on the rig ? You have to be careful with the weight especially depending on how long your levers are going to be. Heat becomes a major issue
  20. MagicEdge
    Aircraft Technician
    Justin' TX USA
    1,327Coins
    Monitors will be mounted on cockpit rig. My set limit is 90lbs. Going light weight on all construction and components. I appreciate concern and don't hesitate to input. Thanks bro!
