My first 2DOF
Discussion in 'DIY Motion Simulator Projects' started by lukas12, Sep 16, 2015.
  1. lukas12
    lukas12 Member
    Poland
    118Coins
    Hello all,
    this is my first project simulator. In total there are many helpful projects that will certainly help me in the construction .
    I am open to all suggestions .
    At the beginning I have:
    Arduino Uno R3
    Moto Monster
    2x potencjomert 10kOhm
    2x wiper motors
    I miss the power supply yet , but I'll buy 12v30A .
    Photos I will keep adding .
    I'm counting on your help.
    Regards
    152,117Coins
    +11,066 / 56 / -2
    With power supplies it is generally good to have some pretty powerful units and for best results use one per motor, particularly if you may plan to upgrade from wipers at some stage in the future.
    A couple of popular options are cheap LED 12v 500 watt power supplies from Ebay or modifying server PSUs, which is simple to do and results in very cheap but powerful PSUs: http://www.xsimulator.net/community...ver-power-supplies-as-cheap-powerful-psus.54/
  3. lukas12
    lukas12 Member
    Poland
    118Coins
    Thank you for sending messages.
    The article is very helpful to me , surely I will remember this
  4. lukas12
    lukas12 Member
    Poland
    118Coins
    How do you think which item to use to connect the frame of the chair ?
    1.[​IMG]
    2.[​IMG]
    152,117Coins
    +11,066 / 56 / -2
  6. lukas12
    lukas12 Member
    Poland
    118Coins
    Thank you for the information
  7. Nick Moxley
    I used a CV, But as Noorbeast said, it does have a minimal amount of twist to it. IMO not drastic enough to really effect anything, But I would suggest you hit up the wreck yard and source a Proper joint from a Driveshaft, Overkill yes, But the last thing u want is a Sloppy U joint after a couple months of use.
  8. lukas12
    lukas12 Member
    Poland
    118Coins
  9. lukas12
    lukas12 Member
    Poland
    118Coins
    Connecting the Arduino Moto Monster .
    Correct ?[​IMG]
  10. lukas12
    lukas12 Member
    Poland
    118Coins
    Slowly begin to add images related to the project .
  11. lukas12
    lukas12 Member
    Poland
    118Coins
  12. dance77
    dance77 New Member
    286Coins
    2DOF, SCN6
    good news thank you!!
  13. bruce stephen
    general contractor
    michigan
    9,115Coins
  14. lukas12
    lukas12 Member
    Poland
    118Coins
    Thank you for the information.
    I've got a interesting reading .
  15. lukas12
    lukas12 Member
    Poland
    118Coins
    A little to relax
  16. insanegr
    insanegr !N$@n€
    Athens
    16,723Coins
    hi @lukas12 nice seeing you are gathering things for your build.
    what kind of sim do you have in mind to built a full frame or a seat mover?
  17. lukas12
    lukas12 Member
    Poland
    118Coins
    Slowly I submit the simulator .
    I made a small model , I have a problem , I made the settings, turn on simulations and mouse move some strip the engine running .
    How to Run the game it's not happening , I set as on http://www.xsimulator.net/simtools-quickstart/
    Where is problem?
  18. noorbeast
    152,117Coins
    +11,066 / 56 / -2
    You need to give a bit more information, like posting screenshots of all of your settings.
  19. lukas12
    lukas12 Member
    Poland
    118Coins
  20. bsft
    why is amount of axis used so low?
