Not connect with game
Discussion in 'SimTools DIY Version' started by Majony, Sep 24, 2015.
  1. Majony
    Majony Member
    54Coins
    SCN6, 4DOF
    Hi all, i'm testing with simtools and not i get connect to the game. I'm testing with two SCN5, i move this with the mouse, but then do not connect with LFS.
    Something must be missing me, I've been seeing in tutorials and my game manager will not let me click on tools or dash (like in the picture), so it should not be well patched and therefore does not make me anything LFS.
    What I need or i'm not doing well?
    My idea is to test the current base of two SCN5 I have with simtools and when I do well I make a base with 4 SCN6 or HyperAxis by Frex, as 4 D-Box
    Thank you very much in advance
    153,866Coins
    +11,154 / 57 / -2
  3. Majony
    Majony Member
    54Coins
    SCN6, 4DOF
    Lol im stupid hahhaha, lot of thanks noorbeast, now i can click on tools and dash, them im tried this to patched the game and see if works correctly. :thumbs
    153,866Coins
    +11,154 / 57 / -2
    Not at all stupid, it is a bug that @yobuddy is aware of.
  5. Majony
    Majony Member
    54Coins
    SCN6, 4DOF
    Yess! now run with LFS. If i need to invert the Axis where is this? In the guide says "You can invert the motor wiring … or invert the DOF in the “Axis Assignments”
    but.....where?
    153,866Coins
    +11,154 / 57 / -2
    Checking or unchecking the small square box determines the direction.
  7. Majony
    Majony Member
    54Coins
    SCN6, 4DOF
    Ahhh Ok thanks noorbeast ! I'm going down pluggins to keep trying things
    By the way, I have seen your work, amazing :cheers
  8. Majony
    Majony Member
    54Coins
    SCN6, 4DOF
    One question about pluggins, some come with updates, the last version with updates its in the top or i have to download the last update?
    153,866Coins
    +11,154 / 57 / -2
    The big orange 'Download' button toward the top right of the plugin overview page will always be the latest updated version.
    If the button is grey and says 'Download Not Available' then you have not spent virtual or real coins for download access.
  10. yobuddy
    51,535Coins
    FYI, This GUI problem is fixed in SimTools 2.0!
