How do I set up Gran Turismo 4 emulator?
Discussion in 'SimTools DIY Version' started by bsft, Oct 2, 2015.
  1. bsft
    Ok. Im stuck. I downloaded the Gran Turismo game and emulator and I dont know further what to do. Does anyony have simple instructions on setting up? It asks for a ROM. But how do I do that?
  2. Jun
    Jun New Member
    South America
    7,048Coins
    What emulator are you using ? Maybe you miss to configure the system BIOS.
  3. Jun
    Jun New Member
    South America
    7,048Coins
    Where is the edit button ? :sos
    Download below and put the "scph*****.bin" files in your "bios" folder.
    BIOS
    :thumbs
  4. bsft
  5. Jun
    Jun New Member
    South America
    7,048Coins
    Download all 3 Bios:
    BIOS
    EUR v2.0
    USA v1.6
    JAP v1.0
    Decompress and copy all 3 "scph*****.bin" files into your "PCSX2/bios" folder located in your "Documents" folder.
    PLUGIN
    USBqemu wheel mod - Version:1-6-2014
    http://pcsx2.net/download/finish/9-plugins/122-usbqemu-wheel-mod.html
    Decompress and copy inside "PCSX2 1.2.1/plugin" folder wherever you installed.
    Then run PCSX2 and choose USA bios.
    Configure your keys, graphics, plugins, etc and load the game (ISO).
    :cheers Cheers
  6. bsft
    beawdy mate! thats what I needed to see, I will check it out later
  7. Boomslangnz
    4,172Coins
    Was about to email you but see you have been sorted
  8. bsft
    Thanks, but not yet I have not.
  9. bsft
    half got there @Boomslangnz and @Jun , thanks fells, just having trouble configuring G27 set up.
    Any Ideas?
  10. Boomslangnz
    4,172Coins
    @bsft you should go to plugin/bios selection and under USB you choose the Qemu USB Driver
    now go to USB and select plugin settings
    set the emulated wheel to whatever wheel you wish it to pretend to be
    make Device Port 1 to Wheel (DX input) click configure
    now set up all the controls etc so click under Steer Left click Reassign and now move your wheel left, throttle press down on pedal etc etc
    HAT UP etc is the D PAD
    once done you can click ok and when you load GT4 it will start spinning your wheel etc as it detects it and you will get all the FFB effects ingame now
  11. bsft
    Thanks @Boomslangnz , is it possible you could do a few screen shots please if you have a chance? Im busy with kids a lot today , and I hope to get back to it in about 11 hrs
  12. Boomslangnz
    4,172Coins
    btw you don't unzip the iso file....leave it as an iso and just launch it that way
    shouldn't need screenshots its pretty simple
  13. bsft
    Ok. Lets see if i can stuff it up
  14. bsft
    ok, im stuck again, I adjusted controls and they seem to work, but now I went into the tart of the program and I am stuck on system/browser config and I cannot go back from that
  15. RaceRay
    Hamburg, Germany
    23,877Coins
    @Jun The edit button appears after one minute for new user. After writing 10 posts you can edit your post immediately.
    • Informative Informative x 3
  16. Taag
    Taag New Member
    247Coins
    thanks a lot for this info. I'm using QEmu ver. 0.5.1 with my Thrustmaster T150 with the lastest firmware but I can't make it working with force feedback. I play with GT4 and I don't stand where the problem is. Can you help me? Thanks again
