Romysim R /R-R par rul
Discussion in 'DIY Motion Simulator Projects' started by julien b, Oct 8, 2015.
  1. julien b
    julien b New Member
    TOURS
    282Coins
    bonjour a tous !
    Mon Projet est une plateforme basée sur trois axes mécanique motorisé qui peu être équipé de manière libre ,
    par type de moteur mais aussi play seat vol , auto, ......
    Les dimensions :
    l : 1300 mm
    L : 1000 mm
    H: de 500 à 600 celon moteur roulettes .;
    Rotation moteur : 60°
    Debattement des axes : 155 mm
    Chassis fixe /
    Chassis mobile :
    L'enssemble :
    Le petit essais en statique bien sympa déjà les vibration du volant se sente dans le siege grace au ressort !!
    Mon siège :
  2. julien b
    julien b New Member
    TOURS
    282Coins
    ! hello all My project is a platform based on three motorized axes Who little mechanical Be Free Way Team, type of engine, but also nominal flight game seat, automobiles, ...... Dimensions: L: L 1300mm : 1000 mm H: 500 600 wheels of celon MOTOR;. Motor Rotation: 60 ° deflection axes: 155 mm fixed / mobile frame Chassis: The enssemble: Buffet very nice static tests already flying vibration feels IN seat thanks to the spring !! My seat:
    153,728Coins
    Do you have a video of your simulator in action?
  4. julien b
    julien b New Member
    TOURS
    282Coins
    Not even I start with just simtool I discover and all this does not seem so simple in any case not clear yet; Moreover, not enough area for play Plugin J hope to put one very soon it would like to say that I finally get to test but we must learn to walk before you can run when I read !! thank you has very soon
