Monster Moto too hot to cool ?
Discussion in 'Motor actuators and drivers' started by Lorien31, Oct 11, 2015.
  1. Lorien31
    Lorien31 Member Gold Contributor
    IT System Specialist
    140Coins
    anyone else has a monster moto that gets to hot to cool with air ?
    I have one on the traction control that only makes it for a minute or 2 testing back and forth.
    Then it shuts down because of overheating.
    I already have a fin on it and also a aircooler.
    Is this normal or just bad soldered and getting hotter because of that ?
  2. speedy
    speedy Well-Known Member
    Alexandria , Egypt
    7,943Coins
    Use a bigger Hammer ...
  3. bsft
    got a photo? maybe we can see something in the photo
  4. Lorien31
    140Coins
    It is a bad Monster Moto anyway, because one chip wasn't working as it should. Got refund for it.
    But looks like that working one has a heat issue, compared to a another fully working one from a another seller.
  5. bsft
    ok then, good to see you got it sorted
  6. SilentChill
    20,592Coins
    Lots of issues with MM's you have to test them first under load and check the voltage output on both chips. I had a nightmare with them but got 12 working ones in the end.
  7. Nick Moxley
    Also your traction loss motor should Never really be "Running" all the time per say. At least with a Proper profile behind it....... Is your frame REALLY heavy or do you have a lot of friction that the motor is then forced to overcome ? can we see a picture of your setup ?
  8. Pit
    30,490Coins
    If you use one MM only for TL then do this:
    http://www.xsimulator.net/community...cts-as-a-single-motor-driver-more-power.5482/
    Less hot, better performance, longer lifetime.
    I use one MM for TL same like you without a fan but a cooler which is only lukewarm. The TL should only break out when the car does. You could optimize your SimTools parameters like using a deadzone and very soft Kp settings in SMC3 or whatever code you are using.
