6dof servo project
Discussion in 'Motor actuators and drivers' started by ho123, Oct 13, 2015.
  1. ho123
    ho123 New Member
    belgium
    198Coins
    Arduino, 6DOF
    for school i am making a full scale 6dof motion sim but instead of making it whit normal dc motor i am making it with servo's. my question is: am i going to need a motor driver or can i just couple it to a power supply and my arduino?
  2. SeatTime
    Hi, short answer - you will need motor driver/drivers. Recommend you have a good look at the Sites Projects/FAQ area - building a working full size 6DOF is not as simple as it may first seem to the uninitiated.
    153,703Coins
  4. ho123
    ho123 New Member
    belgium
    198Coins
    Arduino, 6DOF
    the school will invest in to my project. the construction will be made with materials from school and fortunately we have 6 used servo's from a robot arm.
    and thx for the help
  5. ACSlater
    ACSlater New Member
    359Coins
    why 6dof? Not challenging you, just curious what you believe the realistic benefits are for overall experience
  6. Jun
    Jun New Member
    South America
    7,048Coins
    I found a video explain how to use servo (an industrial ones) with arduino.
    But it's in spanish:
    :cheers
    Cheers
  7. donald
    donald Old Simer New Guys
    Free Job People
    3Coins
    Motion platform, 6DOF
    This is what am i need, but i can't read spanish....T_T
  8. Ashraf
    Ashraf Member
    1,034Coins
    3DOF, Arduino, Motion platform, 6DOF
    Connecting Arduino to the servo driver is a great idea :thumbs
    - have you implemented this project?
  9. Thanos
    Electronics Engineer
    2,907Coins
    Translation:
    Sending pulses and direction from arduino to control it's speed and direction in open loop.
    Arduino needs to use a PLC interface between it's pins and the servo for signal level translation.
    This is not close to any useful way to control a servo. No closed loop or positioning... Perhaps if you add external potentiometer to measure some angle rotation or position of an actuator that the motor is attached to?
