Showroom DX - Compact Simulator
Discussion in 'DIY Motion Simulator Projects' started by noorbeast, Sep 29, 2014.
  1. noorbeast
    153,758Coins
    I have always enjoyed driving but really my sim and messing around with Nords are pleasurable tools to explore VR, I am no hardcore virtual racer.
    I do like the technical challenge of Nords, there are just so many places to mess up, and eventually you will unless you drive like grandma. So not only do you have to get good at knowing the places to be cautious you also have to learn to gather the car up after your own inevitable mistake. That is easier said than done! I have spent plenty of time bouncing off stuff in Nords trying to do both and it still remains a challenge.
    I have added driving Nordschleife IRL, in something decent, to my bucket list, though I suspect it will be a while before I am in Europe again.
    153,758Coins
    I tried out both the F1sr 2006 Ferrari and the Virtua Simulazioni Mclaren MP4-13 this morning.
    I had to turn down the Main Level % even further for the Ferrari, it is a real bone shaker. I do get some weird graphics glitches across the screen with the Ferrari, which seem to be the camera position relative to the model driver, and some odd out of sync animation of the wheel when it is at full lock. The car drives exceptionally well and both looks and sound great!
    I had no issues with the Mclaren MP4-13. It takes more driving finesse than the Ferrari or William FW31 and has much greater heave travel than both.
    I really would appreciate a heads up when the One:1 is release @Nick Moxley!
    153,758Coins
  4. bsft
  5. Edson Lourenço Bezerra
    Edson Lourenço Bezerra Edson Bezerra - Desenvolvedor Open Source
    Analista de Sistema
    Jundiaí
    147Coins
    2DOF, 3DOF, DC motor, Arduino, Motion platform, 4DOF
    translation
    First I congratulate the work.
    I wonder if the movement has balance, ie the central axis moves up and down?
    grateful
    - O
    Primeiramente parabenizo pelo trabalho.
    Gostaria de saber se tem o movimento de saldo, ou seja, o eixo central se movimenta para cima e para baixo?
    Grato
    153,758Coins
    Yes the heave knee moves up and down, I have the heave rod disconnected so this gives an idea of the movement:
  7. bsft
    Huh? all you are showing is normal 2 DOF movement. How does the 3rd motor actually help?
  8. Edson Lourenço Bezerra
    Analista de Sistema
    Jundiaí
    147Coins
    translation
    Now I understand the mechanics.
    Better is the feeling of braking?
    It is possible to act both there and make a jump motion?
    grateful
    Original
    Agora entendi a mecânica.
    Fica melhor a senção de frenagem?
    Existe a possibilidade de ambos atuarem e fazer com que haja um movimento de salto?
    Grato
    153,758Coins
    I am trying to show the heave knee moving the pivot up and down @bsft, a 2DOF does not do that.
    This is un-powered with the heave motor rod removed, so it is possible to move the seat by hand against the heave knee spring. Normally all 3 motors work together for heave.
    153,758Coins
    Yes 3DOF does allow for a greater mix of heave and other movement, like in this early test:
  11. Edson Lourenço Bezerra
    Analista de Sistema
    Jundiaí
    147Coins
    Coins limit to download plugin?
    https://www.facebook.com/Cockpit-Dinâmico-V-anny-907583439316244/
    Currently have a prototype with own plugin for capturing Game Stok Car.
    I want to do test with xyes, but not with the plugin to one of the games:
    Rfactor I or II
    Game Stok Car
    Assetto Corsa
    P Cars or Formula Truck
    You know tells me what the threshold for any of this plugin?
    --0rigi
    Atualmente tenho um prototpo, com plugin proprio para captura de Game Stok Car.
    Tenho vontade de fazer teste com o XSim, mas, não consigo o plugin para um dos games :
    Rfactor I ou II
    Game Stok Car
    Assetto Corsa
    P Cars ou Formula Truck
    Sabe me informa qual o limite para qualquer plugin deste?
    153,758Coins
    • Friendly Friendly x 2
  13. mgill4bu
    mgill4bu Member
    156Coins
    2DOF, 3DOF, DC motor, Arduino, JRK, Joyrider
  14. michto35
    michto35 Member
    france
    92Coins
    Your Sim is very nice and takes up very little space
  15. Hobbs77
    Hobbs77 Active Member
    Connecticut, USA
    875Coins
    2DOF, SCN5
    I agree, nice build! A lot of planning and work went into that rig. Thanks for sharing your pics and videos.
  16. noorbeast
    153,758Coins
  17. AlexinChina
    AlexinChina Member
    China
    371Coins
    Very good explanation and questions!
  18. AlexinChina
    AlexinChina Member
    China
    371Coins
    what‘s surge table?what is it use for?
    153,758Coins
    Surge is the force used to simulate braking and acceleration, see here for a basic diagram: http://www.xsimulator.net/community/faq/dof-angles-forces.15/
    A traditional surge table allows the simulator to move forward and back. My quasi surge is a little bit different as it is designed to move the controls forward and back relative to the user to simulate the haptic effect of surge.
  20. AlexinChina
    AlexinChina Member
    China
    371Coins
    Thank you very much for answering my questions so natural!
