Question for mounting rod to motor and chair
Discussion in 'DIY peripherals' started by hape, Oct 30, 2015.
  1. hape
    hape New Member
    565Coins
    hi
    i have slowly build my rig with a base of steel for the chair and the steering wheel and pedals. Now i don't know whats the best solution to put the motor and the rod together (also the motor and the chairs which should be the same problem). So what do all the diy rig builder there. I have the idea to take a ball bearing solution or is this to much?
    Any ideas (which are tested) would be very nice
    hape
    153,758Coins
  3. hape
    hape New Member
    565Coins
    hi
    thx for your reply. I haven't found this things because i am a german guy and didn't know the word heim joint. So thx a lot for this useful links.
    hape
  4. Barry
    Barry Active Member
    Web Developer
    Northern Ireland
    3,877Coins
  5. Cvetan Cvetanov
    Cvetan Cvetanov Member
    Teteven Bulgaria
    1,462Coins
    2DOF, 3DOF, DC motor, Arduino, 4DOF
    I think you can use car parts like ball joints from scrap yard it will be cheap and strong.
  6. Blame73
    Blame73 Well-Known Member
    8,314Coins
  7. Cvetan Cvetanov
    Teteven Bulgaria
    1,462Coins
    Nice, i want to ask about type of sim i drive 2dof platform with wheel on it i wander if you try this optio is it beter your setup or mine. i never try only seat moving
    153,758Coins
  9. Cvetan Cvetanov
    Teteven Bulgaria
    1,462Coins
    Thank you it was interesting.
  10. bsft
    I was going to reply by noorbeast has FAQ my information and listed it with other information.
