2DOF Compact Arduino MotoMonster
Discussion in 'DIY Motion Simulator Projects' started by OlympusSim, Oct 23, 2015.
  1. OlympusSim
    OlympusSim New Member
    Buenos Aires - Argentina
    608Coins
    Hello everyone
    I start a project with parts of a previously project that had never finished.
    Before i use electronic AMC and H-bridge of Thanos, now with Arduino and MotoMonster
    My Idea is to build something compact as some of those in the forum, but I have some doubts
    that would appreciate if you could help me before make mistakes
    1 - Is there any way to attach levers to the motor shaft without welding and then cant slip.
    2 -Which is the ideal degrees between arm and platform point when sim is a rest level
    I saw a post but not quite understand if you have to be right on top of the motor shaft when
    sim is a rest level
    This is the post title in this forum:
    "Relationship between end of crank arm & mounting point on platform"
    Sorry i can't put a link
    3 - 5v to power the MotoMonster be drawn from the Arduino and this takes the 5v from the usb or
    necessary to give a separate feed
    Then post picture progress
    Thank you
  2. michto35
    michto35 Member
    france
    102Coins
    It's a good start, good luck to you
  3. Pit
    30,490Coins
    The ard is powered by the USB and the MM is powered by the Ard on the 5v line. By all means GND has to be connected too.
  4. OlympusSim
    608Coins
    Thank you Mitcho35
    Ok Pit. Later connect electronic and test, you solved my question 3
    For question 1 i put arm in the way when have load the nuts cant slip because is clockwise. Later put a picture
    Still have doub about my second question is important or i dont care
    Thank you
  5. pedrono2
    pedrono2 New Member
    czech
    213Coins
    3DOF, Arduino
    What drives will be used..??
  6. OlympusSim
    608Coins
    Pedrono2 I guest you ask me for SparkFun Monster Moto Shield
  7. OlympusSim
    608Coins
    Sorry if
    I made a sketch to see if you understand better
    Where should connect mounting point on the platform when is a rest level, assuming the travel arm is halfway
    Should be Point A, B or C
  8. OlympusSim
    608Coins
    Sorry but i need more information
    I make a sketch
    Where should be the point where the platform is connected with the rod
    In the Point A,B or C
  9. SixCyl
    SixCyl Member
    444Coins
    Hi OlympusSim
    For me, i think C is the Good Choice but I could be wrong.
    I ask to confirmation.
  10. Pit
    30,490Coins
    angel between rod and lever should be 90 degree, short said C.
  11. SixCyl
    SixCyl Member
    444Coins
    Thanks to confirm !
  12. OlympusSim
    608Coins
  13. Erwan960
    Erwan960 Active Member Gold Contributor
    3,832Coins
    It should be B.
    To ensure a symmetrical movement, it is necessary that the center of the handle, when it is in a horizontal plan, should be on the same axis as the upper ball.
  14. Pit
    30,490Coins
    Sorry mate I honestly disagree ;) You cannot simulate a symmetrical movement over the full range of the movements using this system. I agree this happens on a very small radius but when you leave the latter as you want to describe the movements it will continue asymmetrically. Furthermore you should think about the nm relationship, as smaller than 90° as worse the efficiency.
    I could be wrong but interesting in any case :)
  15. zigzag49
    zigzag49 Active Member
    723Coins
    I also say B for the same due to the symmetry of movements knowing that the connecting rod should be about 3 times the length of the cam center distance.
  16. insanegr
    insanegr !N$@n€
    Athens
    16,722Coins
    i say B too but only if the lower and higher point of movements will be when the rod comes vertical at the red line
  17. Pit
    30,490Coins
    This is the version which I would prefer:
  18. OlympusSim
    608Coins
    Thanks folks
    Erwan960 your sketch is perfect!!!
    I make some test connecting in "B" point
  19. OlympusSim
    608Coins
    Hello folks. Can you give me some coins to make a test with project cars
  20. Pit
    30,490Coins
    I am missing the magic word...
