My project 2DOF
Discussion in 'DIY Motion Simulator Projects' started by josemanuelrm26, Oct 31, 2015.
  1. josemanuelrm26
    josemanuelrm26 my 2dof
    valencia
    - 8Coins
    Hello I present my project 2dof with front engine and hidden.
    to see if I can just enjoy it and can not wait.
    The cockpit is handmade and is all aluminum.
    Aluminum parts donated by my brother
    Scrapping the seat is given by a friend
    I bought motors and screws.
    and midfielder g27
    151,997Coins
    +11,061 / 56 / -2
    Thanks for sharing the pictures of your simulator, the construction looks nice and clean. Do you have a video of it in action?
  3. josemanuelrm26
    valencia
    - 8Coins
    Hi if I have a video I upload tonight that I have to edit
    Although it not is running simtools but is working.
    the problem that I have with simtools is that when I connect the battery moves me to a position engines and when I open the software I get to do the test in motion leaves me another position axes.
    you know how to adjust this I followed the manual racingmat
  4. bsft
    ask @RacingMat
  5. RacingMat
    21,047Coins
    hello!
    congrats for your building skills
    your concern sounds like "startup - output" and "shutdown output" setup is not done in Game Engine
    can you paste some screenshots?
  6. josemanuelrm26
    valencia
    - 8Coins
    I've checked the connections and are well-connected
    ok thanks
    151,997Coins
    +11,061 / 56 / -2
    You have too large an Axis allocation total, it should be close to 100% and you have 180%, see here: http://www.xsimulator.net/community/faq/axis-assignment-percentage-totals.120/
    I am guessing you have axis limiting low because you are concerned while setting up. Normally it would be 100% and once you know everything works put it back to 100% before spending a lot of time refining a motion profile..
    You can download and follow @Pit's guide to developing a motion profile: http://www.xsimulator.net/community/faq/comprehensive-guide-to-simtools-and-arduinos.118/
  8. RacingMat
    21,047Coins
    follow @noorbeast advice ! :)
    and according to the code, "output bit range" should be 8 bits and not 10bits
  9. josemanuelrm26
    valencia
    - 8Coins
    hello thank everyone for the support I am glad that this forum so alive.
    at the end of the movement that was moving on and the proof was the start of 10-bit I've already changed to 8 and it works.
  10. josemanuelrm26
    valencia
    - 8Coins
    Hello every time I am leaving the simulator more about these advances have done all thanks to this great forum and support you in your and this great program.
    I have some photos
  11. josemanuelrm26
    valencia
    - 8Coins
    Hello my simulator knows someone like could put a 3 engine?
    151,997Coins
    +11,061 / 56 / -2
    Do you mean a 3rd engine for traction loss or heave?
