My 2DOF with DC motors
Discussion in 'DIY Motion Simulator Projects' started by leaedman, Feb 8, 2015.
  1. Seth2Christ
    Seth2Christ Member
    216Coins
    Great simulator :thumbs
  2. leaedman
    leaedman Active Member
    Valenciennes, France
    470Coins
    Thank you Seth2Christ :cheers
    Another little novelty. I have this time change the position of the G27 pedals :D
    ____________________________________________________________
    Encore une petite nouveauté. J'ai cette fois-ci modifier la position des pédales du G27
  3. francois38200
    francois38200 Member
    vienne
    195Coins
    great work leadman :cheers
  4. leaedman
    470Coins
    Thank you francois38200 :thumbs
  5. leaedman
    470Coins
    Non moi ça va, j'adore ! Surtout pour le talon-pointe. Par contre moi c'est l'embrayage qui me pertube un peu. On dirait que la course est plus courte :D
  6. leaedman
    470Coins
    Merci pour les conseils. Pour l'instant je laisse comme ça mais à l'occasion de modifierai les emplacements :thumbs
    _____________
    Thank you for the advice. For now I leave like that but on the occasion of the locations will modify
  7. leaedman
    470Coins
    Another little novelty. I have this time change the position of the handbrake :p More easy to use for me with this position ^^
    Next work, new steering wheel (330 mm from Aliexpress) + buttons plate DIY + paddle shifter DIY :eek: :popcorn
  8. francois38200
    vienne
    195Coins
    nice manu good work :cheers
  9. momoclic
    momoclic Active Member
    Retraité
    Nantes - France
    2,761Coins
    DC motor, Arduino
    Montage original et efficace...
  10. zigzag49
    zigzag49 Active Member
    723Coins
    J'aime le style,le coter mécanique.
    I like the style, the mechanical side.
  11. yeniuser
    yeniuser Member
    Teacher
    Turkey
    313Coins
    Could u please tell us the power and gear ratio of the motors?
  12. leaedman
    470Coins
    • Optimistic Optimistic x 1
  13. yeniuser
    yeniuser Member
    Teacher
    Turkey
    313Coins
  14. leaedman
    470Coins
  15. OlympusSim
    OlympusSim New Member
    Buenos Aires - Argentina
    608Coins
    Good Job!!!
    Very compact design and the handbrake see easy to do
  16. leaedman
    470Coins
    Thanks OlympusSim :)
  17. leaedman
    470Coins
    Work in progress (buttons plate)
    Tomorrow I do the assembly with the steering wheel on G27 :rolleyes:
  18. leaedman
    470Coins
    My new steering wheel from aliexpress (very good quality) and sorry for the bad quality of picture (no orange but red in real :thumbs ) :
    >>Link<< for this product :cheers
    • Like Like x 5
  19. pipis2015
    pipis2015 over-boost
    Athens, GREECE
    10,248Coins
    why did you get a 330mm wheel and not a 300mm?
    Such a big change in diamater requires to lengthen the shifter paddles-if you use them(i see too many extra shifter knobs :)).
    Can you give us some feedback on how the g27 motors "handle" the larger wheel?
    Thanks.
  20. leaedman
    470Coins
    Because the steering wheel 330 mm price is lower and much better finish :thumbs
    The paddles shifter will be changed soon (during delivery).
    I did not understand the last question but the force feed back appears softer, less hard. Sure, this is not the FFB of a Fanatec but not disturbing ;)
