Where to buy H-bridge for my project!
Discussion in 'Motor actuators and drivers' started by Claudemir, Aug 15, 2015.
  1. Guilherme Leite
    Guilherme Leite New Member
    21Coins
    estou procurando uma ponte H para meu projeto, estava vendo aquelas monster shield, no aliexpress será que presta?
    152,093Coins
    +11,065 / 56 / -2
    Google translate - I'm looking for an H bridge for my project, you see those monster shield in aliexpress will be providing?
    By all means post in your native Portuguese but do also include a Google Translation, so members can easily work out if you need help or not.
    Members have had mixed experiences with Monster Moto suppliers, here is a list of suppliers members have recommended: http://www.xsimulator.net/community/faq/reputable-monster-moto-suppliers-testing-before-use.158/
    You can find out more about set up options for MMs here: http://www.xsimulator.net/community/faq/motor-driver-for-arduino-compatible-controller.11/category
  3. Claudemir
    33Coins
    Good night friend?
    Could you help me figure out what's wrong with my code?
    I have this problem as I show in the video.
  4. Pit
    30,490Coins
    hi, please set
    fpid=2
    ki = 0
    kd =0
    ks = 1
  5. Claudemir
    33Coins
    Good afternoon Pit thanks for the reply ok?
    I'm using a new bridge H and I had to modify my code so that this board work.
    Ve as the engine moves but nothing adinta move on KI, KP, KS, which continues with the same problem.
    So as I am unable to see what I did wrong in my code I emviei you that are much more experienced than me so they could help me!
    Des already I thank everyone.
  6. Pit
    30,490Coins
    On the video the potentiometer is moving deliberately? By all means the potentiometer has to be sticked and fixed.
  7. insanegr
    insanegr !N$@n€
    Athens
    16,723Coins
    it's not clear what you have done with the potentiometer but i suspect you have mounted it the opposite way that most people have here otherwise it's totally wrong.
  8. Claudemir
    33Coins
    the axis of the pot is still what moves is the body of the pot! I had everything working perfect in this way but I will replace the H bridge by another stronger and then I had to change the DES code so no more perfect operation! I posted the modified code if someone can take a look to see if all is right with the code I thank
  9. Pit
    30,490Coins
  10. Pit
    30,490Coins
    Sorry I cannot help here, I am not a programmer. The only one who can advise you is @RufusDufus - if he is not too busy...
  11. insanegr
    insanegr !N$@n€
    Athens
    16,723Coins
    same as @Pit said for me too
  12. Claudemir
    33Coins
    Good morning friends? bsft
    I'm sending the card's manual I'm trying to use my project.
    I believe him someone can tell me what better way to use them with my project! Blackmoon.jpg 20151112_105628[1].jpg
  13. Pit
    30,490Coins
    Uiui, your wiring skill you should improve, there is a big space of failure mate, independent fo your issue you have run into.
  14. Claudemir
    33Coins
    I understand perfectly what went wrong soldier!
    This point indicated by you is GND . I will strengthen the welds.
  15. Claudemir
    33Coins
    Pit I am suspicious that this card works on the JRK system!:sos
  16. Cvetan Cvetanov
    Cvetan Cvetanov Member
    Teteven Bulgaria
    1,462Coins
    2DOF, 3DOF, DC motor, Arduino, 4DOF
    You can use logic and 7408 to make direction and pwm.
  17. Claudemir
    33Coins
    Can you explain me better?
    using logic and 7408 to make sense and PWM.?
