Hand brake manufacturing DIY
Discussion in 'DIY peripherals' started by zigzag49, Nov 12, 2015.
  1. zigzag49
    zigzag49 Active Member
    723Coins
    Hi
    Here the handle of the hand brake stem thread with 10mm aluminum tube with a rod of car damper rubber shower to center the filter rod in the tube and the sleeve is an umbrella handle:grin
    -tige threaded 10mm
    alu-tube (shower rod:p)
    - 2 rubber tube inside diameter
    Umbrella -manche
    -1 switch
    -1 Ball 10 mm
    -1 spring
    In the box everyone can do as they want from the moment the passage of the tube in the box is not too wide, so that the handle does not bar a right or left because of the ball, so the material chosen for passage will be either wood or plastic with friction.
    The small plastic part is a setting to lock the lever end of this race.
    • Like Like x 5
  2. Barry
    Barry Active Member
    Web Developer
    Northern Ireland
    3,877Coins
    Nice work!!
    Have you thought about adding a brake master cylinder to give it a hydraulic feel?
  3. zigzag49
    723Coins
    It would have been ideal, I have to make it faster and simpler because it's still better now to have a handbrake rally, it was not practical with the steering wheel button.
    For future handbrake why not;)
  4. momoclic
    momoclic Active Member
    Retraité
    Nantes - France
    2,761Coins
    DC motor, Arduino
    Bon travail comme d'habitude !
    Ce système serai très simple à faire évoluer avec une jauge de contrainte.
    Good work as usual! This system will be very simple to evolve a load cell.
  5. zigzag49
    723Coins
    Thank momoclic;)
  6. Stealthelius
    Stealthelius Member Gold Contributor
    Office Clerk
    Rome, Italy
    96Coins
  7. zigzag49
    723Coins
    Thank you for the advice, the return is fast enough with the gas verrin?
  8. Stealthelius
    Office Clerk
    Rome, Italy
    96Coins
    The return of the course is not so fast and reactive but it is "normal" and depends that witch couse if you want for your handbrake.
    For me it is good and more than acceptable. :thumbs
  9. zigzag49
    723Coins
    Ok Thank you
  10. Stealthelius
    Office Clerk
    Rome, Italy
    96Coins
  11. momoclic
    Retraité
    Nantes - France
    2,761Coins
    DC motor, Arduino
    *Un exemple de simplicité et d'efficacité...
    An example of simplicity and efficiency ...
  12. ACSlater
    ACSlater New Member
    359Coins
    very cool looking rig - elegant in its simplicity
  13. zigzag49
    723Coins
    Thank ACSlater
  14. trust928
    trust928 Member
    brazil
    435Coins
    i need to start build one of these, i love rally too, you gave me some ideas, really really nice design cheers
  15. zigzag49
    723Coins
    Thank you, if it can help, its always fun.
  16. fortissimo
    fortissimo Member
    france
    161Coins
    bon travail
  17. zigzag49
    723Coins
  18. Dmraf
    Dmraf New Member
    Ufa, Republic Of Bashkortostan, Russia
    174Coins
    Not expensive, simple, fast! Good job :thumbs
  19. zigzag49
    723Coins
