Moto Monster China my 2 did work form here
Discussion in 'Electronic and hardware generally' started by hape, Aug 18, 2015.
  1. hape
    hape New Member
    565Coins
    hi
    i have bought a few Moto Monster Shields for Arduino. Every time i bought 2 of them. So now i have different Moto Monster Shield which work more or less. In my opinion (if you check that the picture on ebay has a text on the chip and not nothing) there are a few which aren't build like they should. The most are complete correct only on one side of the pcb. So after a few negative i found this and bought 2 of them to be sure if one is not good (which can be for that price). But they are both in the tolerance (12.4 V input 12.38 -12.39 left 12.4 -12.37 right by 255 pwm). So here is the address on ebay (but i have to say that this is not a guarantee that every Shield will work.
    http://www.ebay.de/itm/310780916584
    But i think if on other addresses there is trouble why not take this where someone has made a good experience.
    so long
    hape
  2. tombo
    tombo Active Member
    1,969Coins
    DC motor, Arduino
  3. MagicEdge
    MagicEdge Active Member Gold Contributor
    Aircraft Technician
    Justin' TX USA
    1,327Coins
    This is where mine were ordered and have bought from this seller many times. Always happy:p
  4. SeatTime
    Just for further info (the OP may have also done this?), I had plenty of MMs in the 20 odd that I have purchased that measured electrically fine, but failed once a load/motor was attached and exercised in different directions/speeds.
  5. Pari
    Pari New Member
    Germany Frankfurt
    566Coins
  6. mrbeginner
    What ever come in my way
    Finland Niinisalo
    - 30Coins
    I have not get any good from Alice... I upload file where you can see how hard is to get money back if you put 5 star on ebay before you test that machine work. It's my own fault, but here is good example to warning others
