My 2DOF with DC motors
Discussion in 'DIY Motion Simulator Projects' started by leaedman, Feb 8, 2015.
  1. pipis2015
    pipis2015 over-boost
    Athens, GREECE
    10,248Coins
    I mean how is the force feedback with the new wheel?
    Stock vs 330mm?
  2. leaedman
    leaedman Active Member
    Valenciennes, France
    470Coins
    Ok, the FFB will not change. It's just less powerful than originally (google translate :confused:), seem to have the force to 50% in settings.
    Otherwise the driving experience is more immersive with 330mm. I love that :cool::thumbs
  3. furiano
    furiano New Member
    - 88Coins
  4. leaedman
    470Coins
    Thanks furiano :cheers
  5. bsft
    where did you get the wheel adapter from?
  6. leaedman
    470Coins
    Yes, I found it on Ebay. Very good quality and and the seller is very serious (I also ordered him paddles shifter) :thumbs :
    >> LINK <<
    :cheers
  7. zigzag49
    zigzag49 Active Member
    724Coins
    Bon boulot , les sensations doivent excellente.
    Combien fait d'épaisseur ton adaptateur ?
    Good job, sensations are excellent. How thick is your adapter?
  8. leaedman
    470Coins
    Merci zigzag49 :cheers
    I did not measure it but I think it is about 1 cm, not more. It is aluminum and the screws are supplied with.
    _________________________________________________________________________
    Je n'ai pas mesuré, mais je pense qu'il fait d'environ 1 cm, pas plus. Il est en aluminium et les vis sont fournis avec.
  9. zigzag49
    724Coins
    Ok merci , c'est on jamais si je me décide à changer aussi.:p
    Ok thank you, that's if we ever I decide to change too.
  10. leaedman
    470Coins
    Pour l'adaptateur il y a encore mieux (malheureusement j'avais déjà commandé l'autre avant :(). C'est mazak515 qui les fait, il est du métier. Astucieux les 2 ouvertures pour passer les câbles (j'ai dû découper le plastique du support d'origine de mon côté :confused:)
    >> Ebay link <<
    :thumbs
  11. TiffWiding
    TiffWiding New Member
    Canada
    216Coins
    3DOF, DC motor, AC motor, Arduino, Motion platform
    I want to know which hardware do you people use for your control of motors?
    Also which type of motors do you use?
    Can you please post here some specifications of the hardware you people use?
    Also do you use any kind of software for the simulation purpose? Which one?
    152,541Coins
    +11,085 / 56 / -2
    @TiffWiding you need to ask such questions in your own thread in the appropriate section, not clutter the thread of another member: http://www.xsimulator.net/community/forums/diy-motion-simulator-building-q-a-faq.31/
    In preparation to asking a question first have a good look through the FAQs, as they cover things like motors with supplier links, control boards of different types, power supplies, building tips and tricks, plus a whole lot more: http://www.xsimulator.net/community/faq/
  13. bsft
    you obviously have not done any reading of the site, have you?
    • Agree Agree x 4
  14. JDTSTLMO
    JDTSTLMO Jim's Sim 2.0 soon to be 3.0 with moving seat.
    STL MO
    305Coins
  15. Icefox
    Icefox Member
    549Coins
    Very nice, I hesitate to make a mod on my driving but I'm afraid that with a wheel 330 force feedback is low on a logitech DFGT
  16. Robbie Teengs
    Robbie Teengs RobbieT
    Director
    South Africa
    372Coins
    Awesome sim, will be using your plans for my system as it is very neat. Will be using wheelchair motors so will need to make some changes to the mounting brackets.
  17. leaedman
    470Coins
    Thank you Robbie Teengd :cheers
    it's nice to know that my plan is helpful to others :oops:
  18. thibault
    thibault New Member
    Brive
    146Coins
    it looks good !
  19. royal40k
    royal40k New Member
    China
    298Coins
    it's great
  20. Sam MAHENDRA
    Sam MAHENDRA mahentheman
    Electrical Engineer
    Sydney Australia
    395Coins
    Great idea mate. I am going to make one like this but I will replace the Switch with a Slide Potentiometer (Aus$5.50). I will match the travel mechanism to suit the travel of the Slide Pot.
