Motor...
Discussion in 'Motor actuators and drivers' started by Stealthelius, Dec 1, 2015.
  1. Stealthelius
    Stealthelius Member Gold Contributor
    Office Clerk
    Rome, Italy
    86Coins
    Hi guys
    I've these motors with a 25:1 motor reductor but i don't know if they work well with a 2DOF in terms of reactivity and torque...
  2. Alexey
    Alexey Well-Known Member
    Electronics Technician
    Adelaide, Australia
    8,066Coins
    With that reducer it will take the operating rpm down to 132 rpm. I think the sweet spot is around 150 rpm ish.
    So it should work but not sure how reactive they will be. The problem is that it is only an 80W motor so you would be limited to a light frame mover or a seat mover. Another issue is that the motor has pre-built electronics inside it already
    so you would have to make sure that you can easily interface with it.
  3. bsft
    132rpm is just fine.
    80 watts is like a wiper motor, but a bit more powerful.
  4. mariano68
    mariano68 Active Member
    builder contractor
    Argentina
    3,339Coins
    2DOF, Arduino, 4DOF
    Would be just fine for a seat mover, better than wipers for sure.
    @bsft usually wipers are around 50watts or less
  5. bsft
    ok a BIG wiper motor then ;)
  6. Stealthelius
    Office Clerk
    Rome, Italy
    86Coins
    This is a great news guys !! But i've one question about torque with 25:1 motor reductor. The nominal torque of these motors is 0.240 Nm and with motor reductor it arrive more or less at 6 Nm, right? I know that the torque of wiper motors is between 12 Nm and 15 Nm. :rolleyes:
  7. Alexey
    Adelaide, Australia
    8,066Coins
    Actually, the torque of most wiper motors is around 5 - 6 Nm. Stall torques will be a bit higher which is what some manufacturers might state. Wiper motors are around the 60 rpm mark which is why they have pretty decent torque for such a small unit. So you could think of it as a faster wiper motor.
  8. Stealthelius
    Office Clerk
    Rome, Italy
    86Coins
    Thanks for your elucidation @Alexey. Now i've just Arduino UNO R3 and monster moto with 2 wiper motors. if i will to choose to mount these 24V motors, what is the right strumentations that i will to use ?
    ... Monster moto have a MAX Output Voltage of 16V...
    Thanks guys
  9. insanegr
    insanegr !N$@n€
    Athens
    16,724Coins
  10. Pit
    30,497Coins
    ...or the vnh5019.
  11. Stealthelius
    Office Clerk
    Rome, Italy
    86Coins
    Thanks to all :cheers
