DIY Accelerometer-logger
Discussion in 'SimTools compatible interfaces' started by mboRacing, Aug 24, 2008.
  1. mboRacing
    mboRacing Member Gold Contributor
    Automatiker
    Switzerland -Eiken
    - 161Coins
    Hello Community
    The Target is to create some new Video's for the Video Plugin, contains real g-forces, out of Rallye or Hillclimb Cars. There are some ways to do this with Professional loggers, but not realy cheap (1000Euros and more), so, its not the way :no:
    http://www.instructables.com/id/Acceler ... rd-memory/
    I have found this DIY Logger, but i have not the knowledge how to create this thing myself. Perhaps there is Anyone how can do this??? (Of course I'll spend the money for the pieces and something for the work!)
    Feel free to contact me or post your ideas here
    Martin
  2. egoexpress
    egoexpress Active Member
    Germany - Frankfurt/M
    421Coins
    I guess you would like to build a portable (most likely stand-alone) accelerometer-logger to take it with you in your rally race car, the race cars of your team members and fellow racers?
    That way we could use this data to feed the X-Sim Video-Plugin with the cockpit-view videos you are capturing in the rally races you are driving, in order to move our simulators syncroniously to the videos.
    If the final device would be small enough, we would be able to take it with us even in rollercoasters. Or perhaps someone could use such a device while driving in the Ring-Taxi with Sabine Schmitz on the famous Nürburgring racetrack, while flying in an sports airplane, or in a race-kart with a helmet cam.
    There would be plenty of possiblities to produce action vids for our simulators! :clap:
    That's a great idea, and I think it would be worth trying to work this out! :thbup:
    Regards
    Christian
  3. egoexpress
    421Coins
  4. mboRacing
    Automatiker
    Switzerland -Eiken
    - 161Coins
    Yes of course - I have good connections to some guys who are placed in the top-ten of rally racing in Switzerland (also Daniel Dada Sieber, S1600), some circuit and hillclimb drivers, also connections to somone who is driving rallye-cross cars :D And near of my hometown there is a little airport where guys are making some air-acrobatic trainings , perhaps they would take the little accelerometer with them in their airplane :clap:
    I cant wait to see some results :yippiee:
    http://www.youtube.com/watch?v=MSrusB-d_7c&feature=relatedhttp://www.youtube.com/watch?v=MV-jY8SAWYM&feature=related
    (Second Video; look at his crazy ride at 4:05, in 5th Gear!)
  5. egoexpress
    421Coins
  6. tronicgr
    tronicgr
    I found a better solution than DIY!!!!!
    Option1 (cheapest):
    You can use a basic Logomatic Serial SD Datalogger from sparkfun for the datalogging... only $39.95
    http://www.sparkfun.com/commerce/produc ... cts_id=752
    ...and for sensors use this Triple Axis Accelerometer Breakout - ADXL330 for $34.95 for simple 3DOF accelerometer (X, Y, Z axis)
    http://www.sparkfun.com/commerce/produc ... cts_id=692
    Option2 (Best):
    You can use Logomatic v2 Serial SD Datalogger for $59.95
    http://www.sparkfun.com/commerce/produc ... ts_id=8627
    ...and this advanced sensor board IMU 5 Degrees of Freedom for $109.95 to have measure all these axis: (Roll, Pitch, X, Y, Z)
    http://www.sparkfun.com/commerce/produc ... cts_id=741
    My new moto: Why get in trouble building such complicate devices if already exist and they are cheap? :D
    Regards, Thanos
  7. egoexpress
    421Coins
    I agree, it's not worth to build it, if there is such a cheap option :blush:
    Well, initially there has been a price of 1000Euro mentioned.
    Martin should give it a try with the parts you've linked :thbup:
    Regards
    Christian
  8. mboRacing
    Automatiker
    Switzerland -Eiken
    - 161Coins
    Oh yess, this sounds realy good :clap: i will have a look to order one of these solutions :hi:
    THX to all
    Martin
  9. tronicgr
    tronicgr
    I agreed with John (planmix) that this is the best solution for sensors to have them placed on the big 6DOF platform, for position feedback or as part of the auto tunning procedure.
    Advanced sensor board IMU 5 Degrees of Freedom to measure all these axis: (Roll, Pitch, X, Y, Z)
    ...and Gyro Breakout Board - Dual Axis IDG300 to measure the Yaw axis that is missing from sensor board above...
    http://www.sparkfun.com/commerce/produc ... cts_id=698
    That is to know that their use isn't limited to datalogging function only... ;D
    Regards, Thanos
  10. mboRacing
    Automatiker
    Switzerland -Eiken
    - 161Coins
    But there's one thing not so good on these accelerometer: the measuring is only -+3g and this is not so very high. I think i will do a test version with this:
    and for sensors use this Triple Axis Accelerometer Breakout - MMA7260Q for simple 3DOF accelerometer (X, Y, Z axis)
    http://www.sparkfun.com/commerce/produc ... cts_id=252
    with selectable ranges (+/- 1.5, 2, 4, and 6g)
    I havent found a sensor like the IMU5 with a better range for forces...
    And is these correct that i dont need something else? (programmer is included onboard i think?)
    Greetings, Martin
  11. tronicgr
    tronicgr
    Hi Martin,
    Yes the Triple Axis Accelerometer Breakout - MMA7260Q is even better to use!
    But it would be nice if you could record the rate of rotation of Bank, Pitch, Yaw axis! These data combined with X,Y,Z accelerations could be used in 6DOF platforms!!! :thbup:
    That's why you also need three Gyroscope inputs like for example by using two of these boards:
    But the decision is yours in the end.
    Just to mention that all these sensors, datalogger etc, are powered from 3.3v source. I suppose that you could power with a 3.7volts LIPO battery (from a nokia cellphone) the Logomatic v2 that has onboard regulator down to 3.3v, and share the 3.3v power to the sensors... This way you can have only one power source and the best its that you can charge the battery over USB!!!!
    The Logomatic v2 device is pre-programmed ready to be used, but supports firmware upgrade over USB if needed!!!
    Regards, Thanos
  12. mboRacing
    Automatiker
    Switzerland -Eiken
    - 161Coins
    Ok i have orderd the logger and the Triple Axis Accelerometer Breakout (MMA7260Q).
    First i will see how it works with the 3 axis and if the import to the video plug will work fine. If there is all ok i wanna order the pitch an roll sensor to complete the logger...
    I hope i will post some results soon...
    Martin
  13. mboRacing
    Automatiker
    Switzerland -Eiken
    - 161Coins
    So das ging ja mal fix: nicht mal ne ganze woche Lieferfrist von USA nach CH :clap: Kostenpunkt ist zZ bei 109$, also noch total fair :happy:
    Und jetzt brauch ich aber hilfe; ich habe mal nen Testaufbau gemacht, funktioniert auch einwandfrei, aber wie kommen jetzt diese Werte in das Video Plugin??
    Bzw wie kann man diese Werte etwas Verdaulicher Visualisieren?
    Im Anhang ist noch die Lgger config Datei und 2 Schüttelmessungen (Zuerst X dann Y und noch Z), einmal in ASCII = Y und ASCII = N
  14. tronicgr
    tronicgr
    I don't know how these values can be imported to video plugin but I could easily import them to excel and represent them in graphical axis.
    From the look of the data, you perhaps are holding the sensor in your hand and shaking it one axis at the time! :lol:
    LOF01.zip
    Thanks for the photo too! It looks really small. Easy it can fit everywhere, or even mount it on a camera to follow its view! :thbup:
    BTW, what is the purpose of the DIP switches?
    Regards, Thanos
  15. mboRacing
    Automatiker
    Switzerland -Eiken
    - 161Coins
    Hello Thanos
    I was shaking the sensor first to x then y and at least to z (By hand ;D )
    the switches are to configure the G-level (1.5, 2, 4, 6 G) and i wasn't shure about the sleep mode so i have connected this signal also to the switches. It works very simple and without any
    problems...
    :cheers:
    Thx, best regards,
    Martin
  16. tronicgr
    tronicgr
    The excel file is in the zip file on the above post!
    I guess I was lucky on guessing the way these motion data was generated, right? :lol:
    Regards, Thanos
  17. mboRacing
    Automatiker
    Switzerland -Eiken
    - 161Coins
    Ich werde nächstes Weekend als Zuschauer am IRC Rallye du Valais sein : http://www.riv.ch
    Dort wird Thomas Büeler (Impreza WRX http://www.rtsw.ch/) den Logger im Auto haben und Daten + Video aufzeichnen. Werde ihm noch einen Satz X-Sim Kleber auf sein
    Auto pappen, vielleicht sieht man ihn ja auf Eurosport (mit etwas glück) : 23.8. 00:00, 24.8. 15:00 (Live), 25.8. 10:45 15:00 (Live)
    http://de.eurosport.yahoo.com/11102008/ ... hweiz.html
    Was denkt Ihr: Einstellung auf 2, 4 oder 6 G ??
    Hier die Bilder des Aktuellen Designes :D :
      72 KB
      759
      143.4 KB
      764
  18. mboRacing
    Automatiker
    Switzerland -Eiken
    - 161Coins
    Das Problem bei der Einstellung ist das sich quasi die Auflösung ändert. So ist bei jeweils die max G = 1056 im aufgezeichneten File... Wenn die G's über den Bereich rausgehen dann
    wird einfach nur noch 1056 bzw 0 aufgezeichnet. Aber je tiefer umso genauer natürlich dann die Auflösung...
    Ich habe diesen Tread auch schon gesehen und muss sagen, bis jetzt kenn ich die AIM software in verbindung mit Spielen gar nicht. Das ganze geht ja in richtung motec bei GTR, ist
    ja eigentlich auch ein Telemtriedaten tool für die Reale aufzeichnung aus dem Motorsport... Werds mir aber mal genauer anschauen (Vieleicht können wir ja die G Aufzeichnung dann
    ebenfalls im Video Plug verwenden (Geht ja eigentlich um die Race Studio Software racestudio-t620.html)
    :cheers:
    Martin
  19. egoexpress
    421Coins
    DAS ist ja mal geil! :clap:
    Kanns auch kaum erwarten!
    Klebe das Ding gut fest, damits beim Bremsen nicht du die Windschutzscheibe fliegt :D
    Gruss
    Christian
  20. egoexpress
    421Coins
    Onboard-video (large)
    http://www.rtsw.ch/web-content/Rennen/J ... %20ES2.wmv
    Meinst du es wäre möglich, die Kamera für diese Aktion etwas mehr in Fahrersichtposition anzubringen? Also den Winkel etwas flacher, und ein kleines Stück nach links/unten. Also irgendwo in die Nähe des rechten Ohres des Fahrers.
    Oder die Fingerkamera direkt an den Helm gebappt :lol:
    Ja, ja, ich weiß, da reicht man die Hand, und dann wollen se gleich den ganzen Arm :brows:
    Fragen kostet mich ja nix..
    Gruss
    Christian
