Some ebay motors
Discussion in 'Motor actuators and drivers' started by Pari, Nov 12, 2015.
  1. nikitojm
    nikitojm New Member Gold Contributor
    manosque
    97Coins
    Hello, About 15kg without the player.
    Nikitojm
  2. lustigio
    lustigio New Member
    Blaster
    Adelaide
    155Coins
    Im using these motors now in my testing and im finding that the low holding torque is giving my problems. The motors seem to jitter because the seat keeps falling back on it self. Any ideas?
    151,480Coins
    +11,041 / 56 / -2
    The 25:1s are easily back driven but being jittery could be your design, hardware or settings, so can you please post pictures of all of them.
  4. lustigio
    lustigio New Member
    Blaster
    Adelaide
    155Coins
    Thanks for your response!
    I am using a 12v 50A power supply to a MM with Arduino Controller.
    Its not letting me upload photos, maybe because I'm new to the forum?
  5. Archie
    Archie Eternal tinkerer
    Wollongong, NSW, AU
    3,796Coins
    Sounds like an off balance issue? I'm using 25:1 and have had them on a foot mount and a Shoulder mount without issue. When powered on, they are very hard to back drive.
    To stop the motors returning to idle after you stop playing a game, you can remove the "Shutdown" command in the Interface settings of Simtools. Or replace the Shutdown command with the Startup command, so that the sim centre's on Exit. (this is what I do)
    Not at home currently, so can't post screens of my Simtools settings.
  6. lustigio
    lustigio New Member
    Blaster
    Adelaide
    155Coins
    Thanks for the info. I'll experiment a little more and upload some photos when I can. I think I'll start my own thread on my build
  7. bsft
    Arduino....ok....bye
  8. shannonb1
    shannonb1 Well-Known Member
    Sales Intelligence
    Virginia
    8,909Coins
    What are your motors? Do you have a questions or are you representing a motor?
  9. nikitojm
    manosque
    97Coins
    Hello I received my new motors from ebay.
    They look good.
  10. nikitojm
    manosque
    97Coins
    Hello, it was a question to know if the motors could be good. Now I bought them, and I'll try.
    Thank you
  11. nikitojm
    manosque
    97Coins
    I must remove the ground inside the motor.
  12. Pit
    30,482Coins
    The motors are only 50W - so do not expect to much. If the seat is well balanced you should have no big issues, but the moves will be not fast like hell.
  13. nikitojm
    manosque
    97Coins
    Thank you for your message.
    50W It's a mistake. I try the motors, for 12V I use 26A for the max torque that I mesured 18Nm. P=UI = 320W
    the motors use 50W about 4A without load. I put a controller between the battery and the motors.
    I just finish to control them. I Put potentiometers on the back and they look like good.
    but 18Nm it's about 1.8Kg at 1 meter and 40kg at 4.5cm. Perhaps it's not enought.
  14. Pit
    30,482Coins
    Please can you upload a better photo taken by the specs?
  15. nikitojm
    manosque
    97Coins
  16. Pit
    30,482Coins
    These motors are rated as 50W motors. Even if I would use the rated current of 10A ("Nennstrom") seeing on the specs for my calculations I would not get more than 120W. The 50W is the estimated continuous power, the other values stand for peak and braking. Sorry to say that and you can hope that I am wrong (which is pretty seldom...)
    • Agree Agree x 4
  17. Pari
    Pari New Member
    Germany Frankfurt
    566Coins
    Hi nikitojm
    extends the power of the motors in your project?
    i´m still searching for a motor that fits.
  18. Ryuuken29
    Ryuuken29 New Member
    Oslo, Norway
    268Coins
    I got a worm gear 50:1 12v hallow shaft, having trouble finding the shaft, don't know the correct name. Do you happen to know? Thx.
  19. Archie
    Wollongong, NSW, AU
    3,796Coins
    @Ryuuken29 - Most members (myself included) have used 12mm threaded rod as a shaft. I think the motor shaft hole is 1/2" imperial, which is about 12.7mm metric. I just inserted 12mm threaded rod, tighten two bolt and spring washers on either side and it's not moved a mm in the year I've been thrashing my sim. :)
    151,480Coins
    +11,041 / 56 / -2
