Showroom Update a cockpit in 2DOF
Discussion in 'DIY Motion Simulator Projects' started by Stealthelius, Dec 9, 2015.
  1. Stealthelius
    Stealthelius Member Gold Contributor
    Office Clerk
    Rome, Italy
    86Coins
    Hello to all of you.
    This is my static cockpit. In these days i'm working to convert it to 2DOF. :grin:grin:thumbs
    153,788Coins
    +11,150 / 57 / -2
    Nice job on the monitor stand :thumbs
    So do you plan a shoulder mount design or something else and what motors and control boards do you have in mind?
  3. Stealthelius
    Office Clerk
    Rome, Italy
    86Coins
    Thanks @noorbeast
    I will to mount two wiper motors to the back of seat and i will to use Arduino UNO R3 and monster moto shield.
    This cockpit was designed only for static use. The only modify that i will do is raise the height for insert all of strumentation to the bottom. :)
  4. Archie
    Archie Eternal tinkerer
    Wollongong, NSW, AU
    3,797Coins
    Hi @Stealthelius - I notice you have a fullsize wheel mounted on the G27? How long have you been using it like that? I've always been tempted to do the same mod but was worried the extra size would put strain on the gears and reduce the life.
    How does it feel to you?
    My G27 gets a beating with the normal wheel size! :)
  5. Stealthelius
    Office Clerk
    Rome, Italy
    86Coins
    Hi @Archie. I've mounted a full size wheel in september. The feel and the strenght of wheel is too light compared to original logitech wheel, infact i will re-mount original G27 wheel next week also for don't damage a gears of wheel.
  6. Stealthelius
    Office Clerk
    Rome, Italy
    86Coins
    @Archie This is a 330mm diameter wheel. IMHO the best compromises is a custom "light" wheel of 300mm of diameter ;)
  7. Archie
    Wollongong, NSW, AU
    3,797Coins
    Thanks for the feedback. Good stuff. I will stick with my normal G27 wheel. I'm done "modding" for a while. Just want to play! :D
  8. Stealthelius
    Office Clerk
    Rome, Italy
    86Coins
    These days i'm testing the movements of wiper motors and all goes fine but i've one bit "problem". When i move the wipers by SimTools, them follow the right direction of effects but have a little jittering to final position... especialy in middle position when i switch on the simulator.
    I've just modify the tolerance in Arduino-code but the movements are not so accurate.
  9. Nick Moxley
    we need FAR more details of your hardware and setup before we can start advising you of the potential solutions.
