3 DOF build (scn5 actuators) new project
Discussion in 'DIY Motion Simulator Projects' started by haroldjames, Dec 12, 2015.
  1. haroldjames
    Electronic Tech
    Ontario Canada
    - 398Coins
    3DOF, SCN5, SCN6
    Hi, Im bulding a 3dof rig using 3 scn5 actuators. I have been busy fabing my frame the last couple of days. I will post pics of my progress as i go. I have used this site to give me ideas and inspiration. Without it I could not do this project.
  2. haroldjames
    Electronic Tech
    Ontario Canada
    - 398Coins
    3DOF, SCN5, SCN6
    Does anyone know if it is possible to use a dc worm drive motor for the traction loss and scn5 for the seat? thanks
  3. bruce stephen
    general contractor
    michigan
    9,115Coins
    Sim tools has room for six interfaces so I would think it would work.
  4. haroldjames
    Electronic Tech
    Ontario Canada
    - 398Coins
    3DOF, SCN5, SCN6
    Thanks Bruce
    153,021Coins
    +11,116 / 56 / -2
    Yes you could, it is really just a case of defining your interfaces in SimTools.
  6. haroldjames
    Electronic Tech
    Ontario Canada
    - 398Coins
    3DOF, SCN5, SCN6
    Thanks noorbeast. Trying to decied to use a wiper motor or scn6 for traction loss.
  7. bruce stephen
    general contractor
    michigan
    9,115Coins
    Use the wiper and send me the scn6 lol.
    Use the scn6........
  8. haroldjames
    Electronic Tech
    Ontario Canada
    - 398Coins
    3DOF, SCN5, SCN6
    Lol, i guess you mean go ahead and use a scn6.
  9. bruce stephen
    general contractor
    michigan
    9,115Coins
    If you have them or the money for scn actuators i do believe they are preferred.
  10. Nick Moxley
    I would NEVER prefer a Permanently mounted birds nest mounted directly behind my seat. Traction loss different story to a point, but still.
  11. bruce stephen
    general contractor
    michigan
    9,115Coins
    Huh, bird nest? What you talkin bout willis? (@Nick Moxley )
    153,021Coins
    +11,116 / 56 / -2
    I am pretty sure @Nick Moxley means the noise SCNs make:
    • Funny Funny x 3
  13. bruce stephen
    general contractor
    michigan
    9,115Coins
    Wow, never knew. That could be quite annoying.
  14. Nick Moxley
    Nice job Prodigy did on the boxes, but unfortunately they still sound MUCH MUCH louder than our gear motor's do.
    I love the guys who say " oh it simulated the chassis sounds " LOL Suuuuure it does.
  15. haroldjames
    Electronic Tech
    Ontario Canada
    - 398Coins
    3DOF, SCN5, SCN6
    Today i did a little more work on my rig. I got the bearing cup holder mounted on the front of the frame. Im using a timken cup and bearing for the front pivot point.
  16. haroldjames
    Electronic Tech
    Ontario Canada
    - 398Coins
    3DOF, SCN5, SCN6
    On the top side of the frame I have welded in a stud to receive the bearing.
  17. haroldjames
    Electronic Tech
    Ontario Canada
    - 398Coins
    3DOF, SCN5, SCN6
    At the back of the frame I have recessed nylon rollers with bearing inserts to ride back and forth for the traction loss.
  18. haroldjames
    Electronic Tech
    Ontario Canada
    - 398Coins
    3DOF, SCN5, SCN6
    On the base frame i have welded a plate for the rollers to ride on.
  19. haroldjames
    Electronic Tech
    Ontario Canada
    - 398Coins
    3DOF, SCN5, SCN6
    This is what it looks like with the both parts of the frame assembled.
    153,021Coins
    +11,116 / 56 / -2
    I am curious about the load rating of the nylon wheels, they look pretty compact.
