Showroom CXC inspired design!
  1. pipis2015
    pipis2015 over-boost
    Athens, GREECE
    10,248Coins
    this may come late...but...
    for everyone that wants to use heatsink without problems ...i sugest placing thermal pads between the chips and the heatsink.
    simple..safe...and costs less than 10 eur/usd.
    edit:i dont think thought that in your case the burnout had to do with the heatsink.
    151,516Coins
    +11,041 / 56 / -2
  3. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    I just order two more JRKs I will be very carefull with the USB cable and make sure they do not twist and bend, no heat sink this time only a fan, I am now very scare of adding a heat sink and scare about bending the USB cable.
    Thank you all...
    • Dislike Dislike x 1
    151,516Coins
    +11,041 / 56 / -2
    Don't be afraid of adding heatsinks, as they are really necessary in how hard we drive JRKs. Just get some that are the correct size for the main chip and attach with thermal tape.
  5. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    Anyone knows where i can go to get iracing car settings like the indycar dallara? The reason i am asking is i am getting a Failed Tech!
  6. Nick Moxley
    17,056Coins
    DONT run the JRK's without heatsinks. Yes they have a thermal shut down protection, But i can guarantee you'll hit that in the first 5-10 min, maybe even sooner if your running the rig as we/you normally would. Pololu made a legit BAD call on suggesting that failure had anything to do with the heatsink and to NOT run one in the future. That's HORRIBLE advice for your situation.
    Milton, WE/community are the guys who make these pololu boards work for our rigs, The Pololu guys have ZERO experience with Motion rigs and stressing the jrk's to the breaking point. So i would honestly take what they say with a grain of salt.
  7. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    Will do! I fill find a small heat sink and also intall a fan to cool down the board.
    Thanks.
  8. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    I need help on deciding on witch power supply I should buy, I found two types that may work:
    A) Universal 12V 30A 360w Switching Power Supply, price US $32.86
    B) Universal 12V 40A 500w Switching Power Supply, price US $56.23
    would the 40Amp burn the JRKs?
    Here is the link of the power supplies:
    http://www.ebay.com/itm/121649502975?var=420643863536
  9. Rastus
    Rastus Active Member
    Sydney Australia
    11,518Coins
    No worries go for the 40 amp you might find you need the extra. I've been running similar 40a LED PSU's on my JRK's for several years, no problem. Order them and go go go. Have fun.
  10. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    Thanks!
  11. pipis2015
    Athens, GREECE
    10,248Coins
    Search for used server power suplies on the net.
    50+ amps @12volt for 10-30usd or so.
    Search inside the forum. You will find lots of info.
    Tested by many of us and working very reliably.
    151,516Coins
    +11,041 / 56 / -2
  13. shannonb1
    shannonb1 Well-Known Member
    Sales Intelligence
    Virginia
    8,909Coins
    I use 2 50 amp...zero issues....you also can power additional fans and have no issues...I use these...
  14. SilentChill
    20,587Coins
    I use 6 x 54AMP 670W dell server PSU's and they seem to be doing okay no problems so far :)
  15. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    Ok my local computer repair had two HP 12v 47amps 575watts, got two for $50 dollars, he also show me the pin i need to jump with the nutral.
    See pictures.
  16. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    Here it is the 12v pin out for the HP 398713-001 power supply:
  17. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    I have two types of potentiometers one is 5k Ohms 3/4 turn and i also have 5k Ohms 10 turn.
    Question: can i used any of those pots? Or do i need other types of pots?
    In advance thanks!
  18. noorbeast
    151,516Coins
    +11,041 / 56 / -2
    Generally speaking 10K pots are traditionally used. However, see @Alexey's comments here re 5K pots and other views in the same thread: http://www.xsimulator.net/community/threads/potentiometers.7372/#post-87390
    Personally I prefer Hall Sensors, even though they are a little more expensive you can't break them if you have a motor run wild, you don't need to gear them, they provide excellent fidelity and have a really long life span: http://www.newark.com/bi-technologi...egoryIdBox=&selectedCategoryId=&categoryName=
  19. Milton
    Dallas Texas
    1,989Coins
    3DOF, JRK
    Thank you ! I am now very interested on the Hall Sensors can they be wired just like a POT? And is there any special setting on the JRK?
    151,516Coins
    +11,041 / 56 / -2
