visualizing DiRT3's data extraction
Discussion in 'Forum and Website' started by leihonglun, Dec 17, 2015.
Poll closed Jul 17, 2016.
  1. what write here?
    100.0%
  2. what write here?
    0 vote(s)
    0.0%
Multiple votes are allowed.
  1. leihonglun
    leihonglun New Member
    china
    262Coins
    Motion platform, 4DOF, 6DOF
    I want visualizing DiRT3's data extraction use SimTools GameEngine ,
    My ststem :win7 x64 + G27
    Installed SimTools-GameEngine + SimTools GameManger +
    Dirt3_Plugin 3.0.2.0
    SimTools-Game Manager See "Game running" when i launch
    Dirt3 .
    Now i can't see Dirt3 data extraction on Output
    Testing.
    No response when i drive a car on Virtual Axis.
    where is error set it?
    please help me!!
  2. value1
    14,239Coins
    Hi @leihonglun
    Can you please post a screenshot of your Interface Settings and your Axis Assignments?
    It could also be an issue with the language settings.
    You might try Windows Control PanelRegion and LanguageEnglish (United States).
  3. leihonglun
    china
    262Coins
    You might try Windows Control PanelRegion and LanguageEnglish (United States).[/QUOTE]
    Hi value1,
    i change language setting a english.and install
  4. leihonglun
    china
    262Coins
    Hi @value1,
    1.I change system's language setting a english.and SimTools installs again.
    Interface Settings and Axis Assignments is normal is default, i don't set it.
    2.Just want use "visualizing DiRT3's data extraction" see Dirt3's data.i need set Interface Settings and Axis Assignments?
    3.SimTools -GameManager IP setting 127.0.0.1. my computer IP 192.168.1.116.what 's have problem?
  5. value1
    14,239Coins
    You need to set some values in axis assignment and define an interface. Just use any COM port on your computer.
    Check the quick installation guide for Simtools.
    Otherwise you will not see any data in Tuning Center.
  6. insanegr
    insanegr !N$@n€
    Athens
    16,726Coins
    you have to create a profile for Dirt 3 in game engine - axis assignments and save it.
    you have to configure game engine- interface settings and save it to see values in tuning center and Virtual Axis
    something like this
  7. leihonglun
    china
    262Coins
    1.IP address 127 0 0 1,Port 4123,Because i see on Sim Tools- Profile Editor -More 'Port Used 4123'. Otherwise according to you ,this is right?
    2.OutputTesting "Axis Tseting" Output Type is 'Dof Output' - game on, "Virual Axis" is show 'Turn On' ,When i running Dirt3.
  8. leihonglun
    china
    262Coins
    I
    I want show image on my PC ,but insert image URL i can't do it use this mode.
  9. leihonglun
    china
    262Coins
    I
    I want show image to you ,but image on my PC ,upload image use insert image URL i can't do it use this mode.
  10. leihonglun
    china
    262Coins
    @insanegr
  11. insanegr
    insanegr !N$@n€
    Athens
    16,726Coins
    4123 is the games port that communicates with simtools not the interface port.
    to see virtual axis moving you have to press '' Turn On '' button when you launch the game
    drag and drop the pic in the writing field to upload a pic but don't know if there is a restriction because you have few posts i think this restriction wouldnt be a problem for supporters
  12. leihonglun
    china
    262Coins
    @insanegr
    This is my set.
    I feel this question is quite strange, may be I do not understand this force feedback racing car racing status data is sent out through what form. Are all of these games have a unified agreement, is through the DirectInput class?
    I think I should understand this kind of force feedback game first, we are how to get their data.
  13. noorbeast
    153,824Coins
    +11,150 / 57 / -2
  14. leihonglun
    china
    262Coins
    1 .DPI set 100%,but show is not change.
    2.path is right.because GameManger show gamerunning when i was luanch game.
    3. Change Axis no effect.
    i need change 'hardware_settings.xml' for Dirt3?
  15. leihonglun
    china
    262Coins
    Thanks for ever one Help me! I find problem. it's patch path..
    D:\DiRT.3.Complete.Edition.No.GFWL.Cracked ..:grin
    Now C:\Users\Your_User_Name\Documents\My Games\DiRT3
    @noorbeast @insanegr @value1 .
    And
    look this when i playing game.
  16. noorbeast
    153,824Coins
    +11,150 / 57 / -2
  17. leihonglun
    china
    262Coins
  18. noorbeast
    153,824Coins
    +11,150 / 57 / -2
    I am presuming this is not an original copy of dirt 3, so that may be an issue, have you messed with any configuration files and if so did you first make a backup that you can restore?
  19. leihonglun
    china
    262Coins
    hi @noorbeast look this .i think this data is abnormal..where is my set is error??
    153,824Coins
    +11,150 / 57 / -2
    The numbers in the green section are representative of extracted data and will vary depending on what is going on in the game, that is normal.
    What matters is tweaking the associated Min and Max values in the Tuning Center to tailor the desired movement, in conjunction with the % value allocated in the Axis Assignment tab of SimTools for that particular axis.
